speedometer sticks
Barley 1981
speedometer sticks
Post by Barley 1981 » Fri Aug 07, 2009 5:50 pm
Sometimes the speedometer stays on zero mph when we set off and a bang on the dash will make it work again, any ideas!?
westonwarrior
Re: speedometer sticks
Post by westonwarrior » Fri Aug 07, 2009 5:57 pm
I will take a guess at its got a chip on the back to convert it to mph and thats playing up
catzi
Post by catzi » Fri Aug 07, 2009 7:00 pm
Mine did that when it was chipped. VERY annoying. :x
Replaced it with a 626 speedo and no problems since.
I Bongo therefore I am
steviebongo
Post by steviebongo » Fri Aug 07, 2009 7:15 pm
where did u get ure 626 speedo catzi?
D n D & K
Post by D n D & K » Fri Aug 07, 2009 7:36 pm
ours does that some times too we just pull over turn of ignition and then start up again this usually works
Post by missfixit70 » Fri Aug 07, 2009 7:39 pm
steviebongo wrote:where did u get ure 626 speedo catzi?
Maxheadroom may be able to help, might be worth dropping him a pm.
steviebongo
Post by steviebongo » Fri Aug 07, 2009 7:43 pm
can u just drop a pm like that even though i,ve never spoke to him before?
Post by missfixit70 » Fri Aug 07, 2009 7:52 pm
Of course you can - just say I sent ya :wink: It's what the pm system is about, sending a private message, just means you know the message is getting to the person you want it to :D
moonshine
Post by moonshine » Fri Aug 07, 2009 10:51 pm
D n D & K wrote:ours does that some times too we just pull over turn of ignition and then start up again this usually works
Mine used to do it too, and when it did the hold light flashed. Like you, I just used to turn off the ignition and start up again. Cured it in the end by fitting a 626 speedo that I got off ebay. It was indeed the converter chip giving problems.
catzi
Post by catzi » Sat Aug 08, 2009 8:03 pm
Got it off eBay - paid over the odds at about £40 but couldn't be bothered trawling round the scrappie's looking for one!
steviebongo
Post by steviebongo » Sat Aug 08, 2009 8:21 pm
looks like i'll have to do the same ,contacted maxheadroom as missfixit70(kirsty)said but he hasn't got any at the mo and my days of climbing in&oot motors are over or so i thought?
