Where can I buy a new Temp sender from.
mikelamb
Post by mikelamb » Wed Aug 05, 2009 10:59 pm
I want to change the temp sensor switch. Can anyone tell Me the part no. or where to buy one please. I have read in a post that wheelquick in Wigan have them but I don't know how to order from them.
Re: Where can I buy a new Temp sender from.
Post by missfixit70 » Wed Aug 05, 2009 11:09 pm
Just give them a ring http://www.wheelquick.co.uk/ , have you tried any of the other usual suspects? Bongobits, AVA, Bellhill, all on the Home page of this site.
mikelamb
Post by mikelamb » Wed Aug 05, 2009 11:19 pm
Thanks Kirsty. :wink:
Post by missfixit70 » Wed Aug 05, 2009 11:21 pm
Starter for ten :wink: (link ammended) - http://www.mazdabongo.com/display.products.php?cId=91 - type in "temperature sender" in the search box
mikelamb
Post by mikelamb » Wed Aug 05, 2009 11:30 pm
Can't get the link to work for Me Kirsty.
Post by missfixit70 » Wed Aug 05, 2009 11:35 pm
Try it now :wink:
Post by missfixit70 » Thu Aug 06, 2009 12:17 pm
If you want to replace the one that feeds the temperature gauge (& therefore the Mason alarm) it seems you need the one with the single connector as in this post http://www.igmaynard.co.uk/bongo/forum/ ... ure+sender -
waycar8 wrote:Hi andy, it does sound like a dodgy temperature sender unit, compatible part number is..
Intermotor 52551, its located under the drivers seat towards the front of the engine just behind the egr pipe.
check this thread out it has a photo of where it is 8)
but it could also be a loose wire on the sender unit itself, or the contacts may just need cleaning, its just 1 wire with a spade conector on it, take it off and clean the contacts, might be a cheap fix [-o<
