Fitting Coolant Alarms
Dean
Post by Dean » Mon Aug 03, 2009 5:56 pm
I know that all the coolant alarms look easy to fit, but being disabled it ain't easy to get around under dashboards etc. Do you think 'normal' garages would fit them?
Re: Fitting Coolant Alarms
Post by missfixit70 » Mon Aug 03, 2009 5:59 pm
It's so easy to fit, anyone should be able to do it that's got the tools & the mobility, if a normal garage can't do it, then they're a bit useless, it doesn't require a bongo specialist, but if they have any doubts - Haydn is always willing to answer the phone if he's about :wink:
Post by haydn callow » Mon Aug 03, 2009 6:06 pm
Hi, It might be worth you having a go yourself and see how it goes...They are easy to fit..
However any garage should be able to fit one in less than a hour.
Perhaps there is another Bongo owner not to far away who would do it for you.
See the web shop below if you want more info about what is available.
If your passing this way I will do it for you.
Post by missfixit70 » Mon Aug 03, 2009 6:12 pm
He's always watching 8-[ :lol:
Dean
Post by Dean » Mon Aug 03, 2009 8:45 pm
Nobody passes Sheppey! but thanks for the offer. I think I'll have a bash and if it goes wrong there's a garage around the corner!
