hold light flashing - should we worry
WannaBongo
Post by WannaBongo » Fri Jul 31, 2009 6:35 am
just back from first longer distance trip in bongo. 400 miles out no problems, then as we start out on the return leg after a couple of miles notice the hold light is flashing and the speedometer not working. Apply the 'girl solution' of pulling over, turning off the engine before doing nothing and then starting again. This works well -no further problems - speedometer working, hold light now off. Onward journey uneventful.
Should we sorting this out or does it sound like a blip to forget about .. Would appreciate benefit of your advice.
scanner
Re: hold light flashing - should we worry
Post by scanner » Fri Jul 31, 2009 10:08 am
If your speedo has been chipped to read in MPH instead of KPH, it could be the chip playing up.
kelv
Post by kelv » Fri Jul 31, 2009 4:27 pm
Wouldn't worry about it until it comes back .
