in the right hand corner,on the top of the dashboard,about 30mm from the windscreen!! Have all Bongos got these
and does anybody know what it's for?!
Cheers!sparkymik wrote:Temp sensor for the aircon
Sparky
The seals have probably dried out and cracked by now - you should run it weekly. It's also the best way to demistM 80NGD wrote: Cheers!I've not used the aircon since I've owned it either!!
Thanks for that RonRon Miel wrote:The (front compartment*) internal temperature sensor for the heater/aircon/Climate Control (if fitted) thermostat is actually behind the little grid, low on the fascia, passenger side. The disc up by the windscreen "reads" changes in the amount of sunlight arriving, perhaps putting the aircon into operation before the internal sensor might otherwise do so (?) - a sort of anticipatory thermostat. Anyone know?
*(The rear sensor is behind the forward section of the floor level grid, offside behind the driver's seat. The rear section of that grid is a heater/aircon air outlet.)
Yes, do keep the aircon occasionally running (10-15 minutes a month is enough) - I failed to do so on a Nissan Primera, and it was going to cost £1,000 to strip it all down to replace the seals and get some working pressure back into it!!! Sold it part ex, with the aircon not working - and still got the "book" part ex price, because I had valeted it well and the dealer neither tested nor asked about it. Phew!
It's easier than that to stop the aircon running - just don't switch it on. If you don't ever switch it on however, you are accepting that you will fairly soon have a Bongo which does not have a working aircon system at all, due to seals dried out by disuse - and even if that's fine for you, it will affect resale value, unless you're lucky as I was above. Once the seals go, it will cost a bomb to strip the two systems down, replace the seals and recharge the systems. Surely, it's worth at least running (front and back) aircon for about 15 minutes a month, to keep the systems intact for the future?Diplomat wrote:Like M80NGO Iam not an aircon person.
Is there any technical reason not to uncouple the aircon pump thereby saving wear and tear?
I appreciate that it only really presents much load when in use.
I just feel that if I don't need it and there is a possbility of it seizing up some time it would be better of not connected.
I am an open window freak (except on motorways etc.) and yes I do realise that open windows can affect fuel consumption but there are some pleasures in life that are worth a little expense!
Hi NFTNew Forest Terrier wrote:Following on fron Ron Miels post. A question from deep ignorance.![]()
Do both air con systems front and back have to be run each weekI run the front system most weeks, but I never run the back heater or air con, as the front seems totally adequate for the whole van. Both back systems still work as I tried them for the first time last week.
The back air con seemed just as cold as the front. Both on is just too much like a refrigrator truck.Anyway the rear passengers prefer the sun roof open.
I assumed all the seals to protect were at the front end and the back was just ducting.
What is the correct drill to follow with the two systemsApart from resale value, I don't care if the rear systems work or not since I just do not need them.
widdowson2008 wrote:....in the back, I'm not really sure. There might be a rear aircon sub-unit in the front compressor which adjusts its compressor output separately. [/color
Not sure how it works but on fiddling with mine, I found that I can control both front and rear independantly (ie. cold in front/hot in back) suggesting separate units. Perhaps there is someone who could explain how that works!!!! cos I have no idea.
As I would like to know how this works, I probably should have started a new thread - sorry, didn't mean to hi-jack this thread.
