Fitting brakes, shims missing help!
mp3oplecarrier
Post by mp3oplecarrier » Tue Jul 28, 2009 8:47 pm
We are just in the middle of changing the arb bushes and droplinks and thought it was a good idea to change the front pads whilst the wheels are off....
Problem is the shims are missing from the back of the caliper bracket on both sides, hence the horrible rattling sound I've had for the last year..
Should they be fitted in all 4 posititions (top, bottom, back and front) or should they be fitted on one end of the pad?
I'd appreciate a speedy answer as we are running out of light!
Steve
dandywarhol
Re: Fitting brakes, shims missing help!
Post by dandywarhol » Wed Jul 29, 2009 2:19 pm
all 4 contact points on the pads fit into steel "shoes" which clip into the caliper, so 4 needed. also 1 steel and coated shim behind the pad on all pads
mp3oplecarrier
Post by mp3oplecarrier » Thu Jul 30, 2009 11:05 am
Thanks Dandy, I should have described the things I was missing a bit better, it is actually the clips which I only had 2 out of 8. I've spoken to Bongobits who kindly offered to send me some FOC, but it'll have to wait until I'm back from holiday now..
Steve
Post by missfixit70 » Thu Aug 06, 2009 1:51 am
