My Bongo has two red LEDs to the right of my steering wheel. The upper one has a switch on it, and it seems to light up when the electrics are on. But what does the switch do? It doesn't seem to switch the electrics on or off. The other one is a few inches below it but is not on a switch. i haven't seen it light up. What does it do?
Jamie
LEDs to right of steering wheel
Re: LEDs to right of steering wheel
Switch could be rear foglamp - no idea about the other.
Have you a coolant alarm fitted..? The solo led could be for that??
If so, it wont light up till you drop yer coolant.
jaylee wrote:Have you a coolant alarm fitted..? The solo led could be for that??
Does when you turn your key tho doesn't it
Dar
I have two on mine, one for the fog light and the other for an alarm. Maybe you have an alarm that's been disconnected if its not flashing.
Paul
Paul
