I thought I'd fit a thermometer in the coolant so I could monitor the temperature!
I saw at the top of the head tank what I thought was a little breather hole! So I tried putting in the thermometer sensor in there – It wouldn’t fit so I slightly enlarged it with an 8mm drill bit – popped the sensor in and drove home.
All was good on the way home the temp gauge didn’t move from it’s 11o’clock position and the electronic gauge told me it went up to 90 degrees C.
When I got home I noticed some coolant on the floor – So I thought DAM
But a few days later I was driving about and the temp gauge in the car went right up and past the 11 o’clock position – So I stopped and had a look at the coolant header tank – It was empty, so I took the cap off and then a massive whoosh of air
Until I drove it and it was exactly the same.
My question after this long winded explanation is: Is that a small bleed hole at the top and should I un-seal it.
I think I will leave well enough alone in the future!
If nothing else works I think I will bleed it myself with the fact sheet off this forum.
