Where can i find the thread for repairing radio ariel?
Pablobongo
Post by Pablobongo » Sat Jul 04, 2009 12:05 pm
PLEASE!!
can someone send me the lik for this.....i cant find it GGGGGGGGGGRRRRRRRRRRRR!!! :evil:
Paul 2002 V6Image
Pablobongo
Re: Where can i find the thread for repairing radio ariel?
Post by Pablobongo » Sat Jul 04, 2009 1:52 pm
Found it........and aerial repaired, using the "cut off flattened areas, drill out, and insert old drill bit and glue together" method. All works a treat!!
Paul 2002 V6Image
Post by g8dhe » Sat Jul 04, 2009 3:06 pm
Another method is buy a length of 6mm Alu. rod from B&Q then drill out the old aerial at the mounting base and using a Tap and Die thread the new rod and tap the hole to replace the entire aerial, the rubber ring and end cap off the old aerial complete the job for less than £4.
