I took the LB out a couple of days ago to recharge it (at which point the CL wasn't working). This morning, I went into the van to do a few bits and pieces (LB still not in vehicle), and the central locking worked a couple of times
Did you have the engine running ? In which case the charging relay will have pulled in and the circuits were being fed from the alternator & S/B.dvisor wrote: and the central locking worked a couple of timesNow its stopped working again. Any ideas as to what's happening?
Thanks Geoff - I guess that would explain itg8dhe wrote:Its sounds like the remote receiver normally fed via fuse 1 is connected to the L/B, but it is also fed from a 30/40 Amp fuse from the under bonnet fuse panel - 16. Its not uncommon for a back path to exist that can charge up a capacitor and can give enough life to the circuit for an operation or two, and then it will need a little while to charge back up again before it happens again - just don't rely on it!
A lot of the meters require you to plug the +ve lead into a separate socket(s) for measuring current as well as turning the switch, if you have left it in the usual V/Ω/low current then you will get odd readings. If you really are only drawing 0.21 Amps I wouldn't get worried at all, that's typically 16 days before the battery is totally flat.bongolow wrote:Scratching my head over that one...![]()
Thanks Geoff. Actually I was a TV engineer in a previous life (anyone remember valves?) so I know about the socket thing...g8dhe wrote:A lot of the meters require you to plug the +ve lead into a separate socket(s) for measuring current as well as turning the switch, if you have left it in the usual V/Ω/low current then you will get odd readings. If you really are only drawing 0.21 Amps I wouldn't get worried at all, that's typically 16 days before the battery is totally flat.
Ah ha, and yes only too well, I have a job seeing the latest SMD and that's not just down to the glassesbongolow wrote:Actually I was a TV engineer in a previous life (anyone remember valves?)
