Tyre pressure
Mack
Tyre pressure
Post by Mack » Fri Jul 03, 2009 10:13 am
Am I being thick (as usual!), but I can't find the recommended tyre pressure for van in my handbook. Just want to know what it should be fully loaded. Anyone?
Re: Tyre pressure
Post by francophile1947 » Fri Jul 03, 2009 12:04 pm
On a plate inside the passenger door frame (or driver's - can't remember which :oops: )
scanner
Re: Tyre pressure
Post by scanner » Fri Jul 03, 2009 1:16 pm
francophile1947 wrote:On a plate inside the passenger door frame (or driver's - can't remember which :oops: )
Driver's - but that's for Japanese tyres under Japanese conditions and I seem to recall that most people haven't found that suits the UK on UK tyres.
And it's in something like sushi per sq/yen.
PS don't ask me why I'm just passing on what I've read on here.
PPS I tend to use about 36psi all round with 215/60-16s if that helps.
Konni
Re: Tyre pressure
Post by Konni » Tue Oct 20, 2009 12:08 am
According to my handbook, for a 2WD diesel unconverted, it is 180kPa front, and 240kPa rear, or 26PSI front and 35PSI rear in English
Re: Tyre pressure
Post by missfixit70 » Tue Oct 20, 2009 12:13 am
Which is usually way too low, as posted on here repeatedly. Usually closer to 38 - 40 psi (obviously check the recommended maximum on your tyres)
Re: Tyre pressure
Post by haydn callow » Tue Oct 20, 2009 11:35 am
I run at 40psi all round....I belive I get a couple more MPG...since I pumped them up from 34F/36R...Seems to handle better as well
davelou
Re: Tyre pressure
Post by davelou » Tue Oct 20, 2009 1:45 pm
I agree totally with hayden, been running mine at 40psi for 3 years.Dave
2.5 Diesel.Full Side Conversion
technophobe
Re: Tyre pressure
Post by technophobe » Tue Oct 20, 2009 5:03 pm
YUP! Agree. But suggest 40psi front and 45psi rear, but check how the tread fits on the road. Tyres will last longer
Richard & Jo
mister munkey
Re: Tyre pressure
Post by mister munkey » Tue Oct 20, 2009 5:09 pm
Agreed.
Although I'm on 18s, running around 38 on the front caused this unbelievably quickly.
It passed an MOT like that but that expensive rubber is fairly well shot & looks shabby. :(
Now try & keep to 40/45.
Re: Tyre pressure
Post by haydn callow » Tue Oct 20, 2009 5:11 pm
MM.that on both fronts ??
mister munkey
Re: Tyre pressure
Post by mister munkey » Tue Oct 20, 2009 5:14 pm
Yep.
scanner
Re: Tyre pressure
Post by scanner » Tue Oct 20, 2009 5:48 pm
Have you had your tracking checked? - if it was just tyre pressure that wear would be on both sides.
mister munkey
Re: Tyre pressure
Post by mister munkey » Tue Oct 20, 2009 6:02 pm
Not the best picture I guess but just nipped out & checked Scanner, insides are scrubbed too.
scanner
Re: Tyre pressure
Post by scanner » Tue Oct 20, 2009 6:41 pm
mister munkey wrote:Not the best picture I guess but just nipped out & checked Scanner, insides are scrubbed too.
It doesn't look to be anywhere as bad though.
It could be worth getting the tracking checked - there isn't usually any charge unless they need to adjust it.
mister munkey
Re: Tyre pressure
Post by mister munkey » Tue Oct 20, 2009 6:42 pm
I'll do that.
Cheers.
