radiator leak
sajafi
radiator leak
Post by sajafi » Tue Jun 23, 2009 1:34 am
hi all
i have been through the search rout but cant seem to fined anything like the problem i have got
witch is all along the top of my rad has just started leeking it is weard one day nothing next day puddle :cry:
so dose anyone have a clue cose i am shore i dont
thanks in advance marcus
Re: radiator leak
Post by missfixit70 » Tue Jun 23, 2009 1:39 am
This has happened with a few people, it splits along the top of the rad along the seam, you'll need a new rad I'm afraid, you may be able to find someone that can recore it, but it'll probably cost as much as a replacement new rad to be honest.
Just make sure it's bled properly as per the fact sheet instructions once its done, good opportunity to flush through the rest of the system too as you'll have to replace the coolant anyway.
sajafi
Re: radiator leek
Post by sajafi » Tue Jun 23, 2009 6:44 am
i thought it might be the case
well of to the shop i go :(
cheers for the prompt reply
marcus
Re: radiator leak
Post by mikeonb4c » Tue Jun 23, 2009 2:11 pm
Oh and general agreement here is its worth paying extra for a quality one. Word is that some of the cheapos on ebay don't work as well (fewer tubes? etc.?), and thats not good news for a hard working Bongo 8)
So check the spec before writing your cheque :lol:
ScubaBongo
Re: radiator leak
Post by ScubaBongo » Tue Jun 23, 2009 2:23 pm
You also might want to find out WHY the top crimps failed.
It could be old age, or it could be because the system has become pressurised.
Don't mean to worry you, but you wouldn't want to kill a 2nd rad in finding out...
brorabongo
Re: radiator leak
Post by brorabongo » Tue Jun 23, 2009 2:34 pm
I have the cheapie from Ebay fitted just now, I will be getting an original next.....maybe sooner that expected. :cry:
Rad splitting
Also on an original there's no silly pipe at the fiiller neck that needs blanked. :evil:
ボンゴの激怒 pictures
ex25er
Re: radiator leak
Post by ex25er » Tue Jun 23, 2009 5:11 pm
Marcus
I had the same problem & was glad I had a low coolant alarm as a I was just starting a 250 mile motorway run!!
Allans in Plymouth supplied & fitted mine, so he may well be worth you trying. He put a heavy duty one in, which I think is all brass as opposed to plastic and aluminium. Cost a bit more but I suppose I get a bit extra piece of mind. Having said that, the original plastic and ally job lasted 13 years....
Phil
