internal electrics off a leisure battery
coolcampers
Post by coolcampers » Sun Jun 21, 2009 4:57 pm
Hello
please could somebody help me. I have fitted a leisure battery to the bongo but would now like to run all the internal electrics (lights/ciggie lighter) off it. Can anybody explain to me how I can do it in a simple step, by step way. I have already seen a couple of posts here but although explained it isnt immediately obvious. Firstly they dont mention the internal lights, only the cigar lighter and electric blinds ( i dont have elecric blinds) and secondly they state to connect to a power supply running from the leisure battery. I,m not sure where I am supposed to look for this. Please help the totally clueless ones amongst you who have no idea how electricity works. cheers
MountainGoat
Re: internal electrics off a leisure battery
Post by MountainGoat » Sun Jun 21, 2009 5:08 pm
A number of members are experts at doing this modification. To direct you towards one we need you to put your location on your profile.
Tony
coolcampers
Post by coolcampers » Sun Jun 21, 2009 5:14 pm
sure, I am in cardiff
MountainGoat
Post by MountainGoat » Sun Jun 21, 2009 5:36 pm
All the leckies that I know are in the North West and in Southern Scotland. Well I am from Liverpool originally of Scots parents. You could try Pm'ing Madmile for help, he converts Bongos to campervans for a living. He is located somewhere in south Wales.
Tony
timmyt
Post by timmyt » Sun Jun 21, 2009 5:46 pm
As mountaingoat mentioned madmile is a great source of knowledge and from my experience a very helpful and approachable guy,he is based in Caerphilly.
If your ever down my neck of the woods id be happy to take a look for you.
coolcampers
Post by coolcampers » Sun Jun 21, 2009 5:47 pm
ok, now the next obvious question. how do i get hold of madmile. remember i am an apprentice so am not used to this forum and cant see him here. thanks
MountainGoat
Post by MountainGoat » Sun Jun 21, 2009 6:00 pm
One way is too look through the different posts until you come to one by Madmile. Then click on PM at the bottom and send him a message.
Another way is to click on "New Messages" at the very top of this page then type in Madmile as recipent and then type out your message to him.
Tony
westonwarrior
Post by westonwarrior » Sun Jun 21, 2009 6:58 pm
madmile
or check the member list
what have you done so far? split charge? How have you gone about it
coolcampers
Post by coolcampers » Sun Jun 21, 2009 7:16 pm
firstly thanks for all the advice. it really is appreciated. secondly, how far have I got? I have bought a battery, ordered a tray and a split relay kit. But fitting that should be fine as I have some simple instructions for it. its just getting the internals to run from this battery that is the difficulty
cheers
westonwarrior
Post by westonwarrior » Sun Jun 21, 2009 7:29 pm
Its not a willinton kit then?
if not its a case of getting a fuse box and running the wires through to the main fuse box and replacing a few fuses with the wires it is simple once you have set up the new fuse box
coolcampers
Post by coolcampers » Mon Jun 22, 2009 4:20 pm
its only simple if you know what your doing, sadly i dont. any further top tips?
corblimey
Post by corblimey » Mon Jun 22, 2009 4:49 pm
Here's are a couple of threads that may help with pics of my set up.
http://www.igmaynard.co.uk/bongo/forum/ ... hp?t=11189
Or this one, read on from Madmile's post
http://www.igmaynard.co.uk/bongo/forum/ ... se#p250829
HTH :)
coolcampers
Post by coolcampers » Mon Jun 22, 2009 6:25 pm
thanks that really does help loads. I am building a picture. now any suggestions where to route the wires into the van from the battery?
thanks
westonwarrior
Post by westonwarrior » Mon Jun 22, 2009 7:24 pm
depending how you wat it realy there are rubber grometts behind both batteries and a plastic blank in the center all of which can be used
madmile
Post by madmile » Mon Jun 22, 2009 7:52 pm
coolcampers wrote:thanks that really does help loads. I am building a picture. now any suggestions where to route the wires into the van from the battery?
thanks
PM'd you Mark.
As for routing cable, I use the big grommet behing the main battery as its closest to the fusebox.
Ed
