K & N airfilters thinking of changing my air filter
				paul&tracey
I'm thinking of changing the standard paper air filter to a K&N air filter part no E-9280. Does anyone have views on this or have used the filters. I understand the airflow is increased. I have the normal 2.5td engine, will this be ok with the K & N filter?
						- dandywarhol
Re: K & N airfilters thinking of changing my air filter
yep - might make the engine a little perkier, increases the induction noise a tad and lasts forever!
I just cleaned and reoiled mine yesterday after abot 15000 miles - some of it on dusty eastern european roads/tracks......it was needing done!
				paul&tracey
I take it from your reply you have been using the k&n filter on your bongo, has the mpg increased? does the extra air intake have any bad effects with the engine?
Cheers Paul
						Cheers Paul
- dandywarhol
Can't detect any mpg improvement, but I THINK it feels a little sharper on aceleration. It won't do any harm to the engine unless you think the standard/aftermarket filter will filter more dust out.
				paul&tracey
Yeah, my only concern was the extra air intake with the K&N if this would cause any problems, it seems not
I've been using one for about a year. Like Dandy, I've not noticed any difference to fuel consumption, but it does seem to run better
				paul&tracey
Great, if you've had no problems and been using the filter for a year it sounds a fairly good investment
Mines been in about a year too, I'd say it felt a tad more lively once fitted. certainly not noticed any negative effects.
Mmm. Been thinking about trying out one o these K & N filters after seeing an ad on the gents wall in a service station...
So the performance improvement's not just a fallacy then?
I'd be careful about those ads Jayleejaylee wrote:Mmm. Been thinking about trying out one o these K & N filters after seeing an ad on the gents wall in a service station...
True. A3 size ad above the stalls, blah "so many years of air filters, performance", blah blah!!missfixit70 wrote:I'd be careful about those ads Jayleejaylee wrote:Mmm. Been thinking about trying out one o these K & N filters after seeing an ad on the gents wall in a service station...
There was one for breakdown cover too!
Last ad I saw in a m'way bog said -
"Look up"
"Look up"
"You're now p*ssing on your shoes"
Trouble was - it was correct!!
Mike
									"Look up"
"Look up"
Mike
Curator of the Bridgwater Motorbike Collection
				BongoMTBer
Changed mine a couple of days ago.  Certainly feels a bit more sprightly but that could be just because it needed a new filter anyway.  It makes me feel better inside though and that is what matters, eh?
