i've been thinking about the bits i need to do to the bongo, and has anyone put a solar panel on the roof to put a trickle charge into battery or to use bits in the van...???
Glad to see you're back, Kirsty, I missed your "shining wit"missfixit70 wrote:I wonder if the free electrickery gained by the solar panels is enough to offset the reduction in mpg due to the drag?
I think you put a few to many letters in there, remove "ningwi" & it's more applicablestilldesperate wrote:Glad to see you're back, Kirsty, I missed your "shining wit"missfixit70 wrote:I wonder if the free electrickery gained by the solar panels is enough to offset the reduction in mpg due to the drag?
SD
I don't drive in womens clothes (anymore!)missfixit70 wrote:I wonder if the free electrickery gained by the solar panels is enough to offset the reduction in mpg due to the drag?
Did you try laying them flat on the roofSimonV wrote:Looked at some Solar panels and it was looking like a good idea before I realised that if I fitted the solar panels on the roof I could no longer fit the van in the car park at work due to the increase in height
At least I realised before I bought them
They were flat. Only got 5mm of clearance in the multi story at work so you have to be a bit careful. The bongo does go in however I keep a check on the tyre pressures just to be safestilldesperate wrote:Did you try laying them flat on the roofSimonV wrote:Looked at some Solar panels and it was looking like a good idea before I realised that if I fitted the solar panels on the roof I could no longer fit the van in the car park at work due to the increase in height
At least I realised before I bought them![]()
SD
