fitting aerial
rondor
fitting aerial
Post by rondor » Sun Jun 07, 2009 5:34 pm
When we got the bongo with mushroom roof,of course the arial is missing also radio ,fitted connectors from Halfords which is ok ,the arial connection is at radio end,where the hell is the other end
I know they are normally on roof but with mushroom it's not there..the question? where to fit one
Any ideas. rondor30
vanvliet
Re: fitting arial
Post by vanvliet » Sun Jun 07, 2009 6:10 pm
I have a Blaupunkt DAB radio and the aerial is fitted to the windscreen .The wire runs discreetly up the window side rubber and the little black box is (double sided) taped behind the mirror .Works a treat for me :D
Origo bio stove - no Bongo!
Re: fitting arial
Post by g8dhe » Sun Jun 07, 2009 6:18 pm
The aerial isn't on the roof its mounted on the metal just above the drivers door. The aerial cable runs up the o/s window screen column and back to just beyond the drivers head.
See the Lush projects diagram
rondor
Re: fitting arial
Post by rondor » Sun Jun 07, 2009 10:43 pm
g8dhe wrote:The aerial isn't on the roof its mounted on the metal just above the drivers door. The aerial cable runs up the o/s window screen column and back to just beyond the drivers head.
thank's for your comments, It's just a mystery where it;s disapeared to I have had all trim off no arial cable
i will have to go with windscreen one Thanks all
rondor
Re: fitting arial
Post by rondor » Mon Jun 08, 2009 7:39 pm
vanvliet wrote:I have a Blaupunkt DAB radio and the aerial is fitted to the windscreen .The wire runs discreetly up the window side rubber and the little black box is (double sided) taped behind the mirror .Works a treat for me :D
Hi got windscreen arial question? where did you fix 3 inches long braided earth
and could you tell me which fuse is the radio one Ron
vanvliet
Re: fitting aerial
Post by vanvliet » Mon Jun 08, 2009 8:43 pm
Fraid I can only describe the blaupunkt DAB one .It is a black sheathed single outer cable ( might be more than one wire inside )which simply plugs into the rear of the radio I tucked it up the side of the windscreen under the rubber and then under the headlining at the top
Re: fitting arial
Post by g8dhe » Mon Jun 08, 2009 8:46 pm
rondor30 wrote: tell me which fuse is the radio one Ron
Fuse 1 supplies the permanent +12 volt supply and Fuse 8 is the switched +12 volt supply.
rondor
Re: fitting arial
Post by rondor » Wed Jun 10, 2009 9:14 pm
Thanks everyone radio fitted (works ) :lol:
