help will these fit
peanutcrusher
help will these fit
Post by peanutcrusher » Thu Jun 04, 2009 11:31 pm
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0396143103
if so please don't bid on them i've been looking for ages [-o<
Bongo now work later !!! :) :)
mister munkey
Re: help will these fit
Post by mister munkey » Thu Jun 04, 2009 11:38 pm
Risky call with 11 minutes to go but even if they did fit, the tyres wouldn't be up to it.
Another £200+ to spend . . . . .
scanner
Post by scanner » Thu Jun 04, 2009 11:40 pm
If they are off an MR2 I wonder if they will carry the load of a Bongo which weighs almost twice as much.
As to whether they'll fit??
Why not use the alloy fitment guide posted earlier - that's what it's for.
peanutcrusher
Post by peanutcrusher » Thu Jun 04, 2009 11:42 pm
best not to touch then i take it
i used the guild but its allover the show i take i need to look and list each one that matches the listing you posted
waycar8
Post by waycar8 » Fri Jun 05, 2009 9:55 am
they would have fit, but as mentioned, another 200 nicker for the right tyres with correct weight.
scanner
Post by scanner » Fri Jun 05, 2009 10:04 am
waycar8 wrote:they would have fit, but as mentioned, another 200 nicker for the right tyres with correct weight.
Not if the centre hole is only 60mm they won't and the alloy wheel fitting guide says the MR2 has that size centre hole.
waycar8
Post by waycar8 » Fri Jun 05, 2009 10:12 am
AH never checked just read the 115 pcd :shock:
