Help Please! passenger electric window stopped working!!!
Aunt Trumpet
Post by Aunt Trumpet » Thu Jun 04, 2009 1:31 pm
Our passenger side window has stopped working, I'm assuming its not the switch as it doesn't work from the drivers switch either. I've got the internal door panel off and inspected all the wires that run between the door shut just incase the door movement has caused a break but all seems fine there. I'm at a bit of a loss now as to what to look at next, any ideas?
Thanks for any help. :?
Re: Help Please! passenger electric window stopped working!!!
Post by mikeonb4c » Thu Jun 04, 2009 1:34 pm
Aunt Trumpet wrote:Hi,
I assume you've checked that you've not inadvertently flicked the little rocker switch on the drivers side switch panel that is used to disable the passenger window from opening?
Post by Muzorewa » Thu Jun 04, 2009 1:35 pm
Assuming you haven't inadvertently switched the passenger side off with the switch on the driver's side, most likely is the wiring between door & body. In particular, check the bottom of the loop where it is held with a cable-tidy, as well as where it goes through the grommets. To check the wiring properly you'll have to remove the corrugated outer insulation.
Aunt Trumpet
Post by Aunt Trumpet » Thu Jun 04, 2009 1:48 pm
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Sorry, I've been a tw@t. The lock was switched off! :oops: BUT, it is my wifes bongo and the kids play in it and I didn't know the switch existed and and and.......(my excuse and I'm sticking to it.! :D
Tell you what though, you guys are bloody quick!
Mods, please delete this post before Eat Aunt gets on here because i'll never live it down for the rest of my life!!
Thankyou. 8)
Eat Aunt
Location: Bongoing since 2005 in the Portsmouth area :)
Post by Eat Aunt » Thu Jun 04, 2009 1:53 pm
Aunt Trumpet wrote::lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Thankyou. 8)
TOOOOOOO SLOWWWWWWWW ha ha ha
You Gormless Aunt
\:D/ :lol: :lol: :lol: :lol: :lol: :lol: [-o<
20 YEARS BONGO-ING
Black Std 2WD AFT
Now 2001 WHITE V6 Tintop ... 253,000 Km
Aunt Trumpet
Post by Aunt Trumpet » Thu Jun 04, 2009 2:03 pm
Bum! :lol:
waycar8
Post by waycar8 » Thu Jun 04, 2009 2:17 pm
:lol: :lol: , simplist things please most :lol:
Glad it was the "easy fix", your not the first and certainly wont be the last to do the same.
scanner
Post by scanner » Thu Jun 04, 2009 2:40 pm
waycar8 wrote::lol: :lol: , simplist things please most :lol:
Yep all you need to do now is lock yourself in the back by fiddling with the child lock on the sliding door. :lol:
Post by francophile1947 » Thu Jun 04, 2009 3:45 pm
scanner wrote: Yep all you need to do now is lock yourself in the back by fiddling with the child lock on the sliding door. :lol:
Oh yes :twisted: - I've taped the ruddy thing up now :lol: :lol:
Post by mikeonb4c » Thu Jun 04, 2009 5:51 pm
Blimey - I actually did something useful for once. DON'T ANSWER THAT! :lol:
lizard
Post by lizard » Thu Jun 04, 2009 9:14 pm
mikeonb4c wrote:Blimey - I actually did something useful for once. DON'T ANSWER THAT! :lol:
Only 213 to go :wink:
F Zappa
David Edwards
Post by David Edwards » Thu Jun 04, 2009 9:33 pm
Well I can't say anything cause I did the same thing and almost had the door off before the missus asked " if this little switch should be unlocked" the air was blue. :)
Post by mikeonb4c » Thu Jun 04, 2009 10:15 pm
Yea but I'm feeling tired and wonder if I'll make the Big One before Stourport. Well at least I've just upped it by one :lol:
