rear heating/cool air
o.k.found switch as advised,the switch does not light up when switched on,so no rear heater working. Fixed 12v cigarette lighter,thank you for help. I am going to embaress myself again .what is the switch on the right of heater switch ?.
Re: rear heating/cool air
If it's got a picture of an engine on it, it works a flap in the exhaust to heat the engine quicker. Best advice is don't touch it - you don't need it in the UK and car will run really badly if you do
