engine block
cuffemark
engine block
Post by cuffemark » Wed May 20, 2009 9:31 pm
Greetings to all
Painful question, is a small split in the engine block repairable? [-o<
westonwarrior
Re: engine block
Post by westonwarrior » Wed May 20, 2009 9:34 pm
As far as I am aware only with a new engine
still not too bad as the go for about £850 but you then need a fitter
dandywarhol
Re: engine block
Post by dandywarhol » Wed May 20, 2009 11:38 pm
Depends where the split is - if it's on the head mating surface then I'd say no.........if it's elsewhere then it could be welded.
