BONGODADDY
Post
by BONGODADDY » Fri May 15, 2009 4:45 pm
I know these two questions have been asked many times, but after looking through the answers previously looks like there are a few different responses, probably there is more than one answer?
Anyway, just need to know what engine oil is the "Best" for a 2.5 d, and i am considering upgrading my 15inch alloys later in the year to 17inch but do not want to make the van unstable in anyway (the tyres i have at the moment are 100 h rated and 215 65 15 which i understand are correct and standard), If i do upgarde to 17inch wheels and tyres i would prefer to fit a set that i dont have to try to work out my actual speed compared to what the speedo is reading due to any variance from my 15 inch wheels (Is there a tyre size for 17 inch that eliminates both of the issues?).
Thanks to anyone who can help.
Post
by francophile1947 » Fri May 15, 2009 6:47 pm
Oil should be 5W/30, but I use Shell Helix 10W/40 because that's what most of the dealers use.
215/55x17 is just about the nearest circumference to the 215/65x15 standard tyres. I've got 225/55x17 fitted and the speedo is virtually spot on with the sat nav. You can do your own comparisons here
http://www.miata.net/garage/tirecalc.html
BONGODADDY
Post
by BONGODADDY » Sat May 16, 2009 4:38 pm
Thanks for your replies, got my oil and topped up the level, i followed your advice John and purchased 10w/40 castrol gtx diesel as that was the "Best Branded" oil that they had.
Thanks again.
Will let you know if/when i upgrade my wheels.
