power output
peanutcrusher
power output
Post by peanutcrusher » Wed May 06, 2009 10:39 pm
can anyone help me with this one.
I'm looking at putting a second battery in my bongo for the audio system, blinds and the internal lights.
I've had a split charger fitted and I'm just going to fit the battery what i need to know is how good are the alternator i guess that they had half decent because of the vans being used for conversion to campers.
can anyone tell me the output of the alternator and how big of a second battery i can get away with. i don't want to cook the alternator..
Bongo now work later !!! :) :)
mister munkey
Re: power output
Post by mister munkey » Wed May 06, 2009 10:45 pm
From memory its around 2.1kw, well up to the job.
A 110ah battery will slot in if you get a big enough tray.
daveblueozzie
Re: power output
Post by daveblueozzie » Wed May 06, 2009 10:48 pm
As Chris has said a 110 amp battery will fit ,its a tight squeeze but will go in if you have a long enough battery tray.
Lost without my Bongo.
peanutcrusher
Re: power output
Post by peanutcrusher » Wed May 06, 2009 10:53 pm
the tray is big enough to take a 110ah battery.
i take it that 110ah will power all my audio kit with no problem.
I'm powering:-
head unit
DVD multi changer
4 x screens two of which have DVD players in them.
5.1 DTS audio decoder
3 amps
2 or 4 12" subs
oh and a Wii
:D
daveblueozzie
Re: power output
Post by daveblueozzie » Wed May 06, 2009 11:03 pm
peanutcrusher wrote:the tray is big enough to take a 110ah battery.
I'm powering:-
head unit
DVD multi changer
3 amps
2 or 4 12" subs
oh and a Wii
:D
depends how long you have them on for, and how many switched on at one time. #-o
peanutcrusher
Re: power output
Post by peanutcrusher » Wed May 06, 2009 11:20 pm
most of it will be running at the same time, running time at least a film or two if not more that's without the engine running.
do you it will last that long or not
stringman
Re: power output
Post by stringman » Wed May 06, 2009 11:35 pm
The calculation is I (current) x V (voltage) = Watts
So add up the wattage of all the appliances you are running and divide by 12 volts, this will give you the current (amperage). If using a 110 amp hour battery, divide 110 by the amperage and this will tell you how long you can run these appliances until the battery is flat
Tin top Bongo camper, Peugeot Partner Combi, Kawasaki ZRX1100, Yamaha SR250SE
peanutcrusher
Re: power output
Post by peanutcrusher » Wed May 06, 2009 11:39 pm
cool thanks a great help.
can you get any bigger batteries that 110ah to fit the bongo
stringman
Re: power output
Post by stringman » Wed May 06, 2009 11:45 pm
110 ah is actually the biggest I've see. You could run a couple in parallel but then you're getting complicated and you would need to find somewhere inside the vehicle to mount the second (or third as it would really be) battery.
Re: power output
Post by mikeonb4c » Wed May 06, 2009 11:46 pm
I wonder how well the LB will cope with that lot all working together. I get teh feeling with mine that it doesn't much like anything approachign a serious current draw before the voltage drops, though mine could be a bit duff. Ron Miel has talked about his Elecsol battery in persuasive terms - his sounds like it may cope better than many with higher current drains. But whichever way you cut it, I wonder how long you would get before the LB complained :roll:
Re: power output
Post by Simon Jones » Sat May 09, 2009 12:41 am
I think there's a bit more involved in the calculations than meet they eye. 110 A/hr battery will on the face of it provide 110 A for 1 hour, or 1 A for 110 hours, but as it will be completely flat by that point, all the the gear being powered will have packed up long before then.
There's tons of info out there - here's just one that goes into some of the technical reasons why the above calculations are unrealistic http://www.windpowerunlimited.com/batte ... _Hours.htm
In general, get the highest capacity battery that you can physically fit & ensure your split charger, fuses & wiring is up to the current required to charge a completely flat battery. It seems the Bongo alternator is more that powerful enough to keep both batteries charged.
