changing front discs..
bongomaan
Post by bongomaan » Tue May 05, 2009 9:09 pm
going to do this on Saturday,cant find a fact sheet or much in search,i hope its just one on one off but is there anything i should look out for ? any tips would be appreciated,regards neil.....
welsh winger
Re: changing front discs..
Post by welsh winger » Tue May 05, 2009 9:43 pm
Hi Neil,
easy job, take the brake caliper off and the disc should pull off, OK it may need a knock with a hammer from behind.
Nick
Welsh Winger
bongomaan
Post by bongomaan » Mon May 11, 2009 5:35 pm
cheers nick you were bob on...a small offering of advise for others..when re-fitting caliper put two studs on to hold the disc inplace ,but what an easy job hour and a half front discs and pads....tidy....
welsh winger
Post by welsh winger » Mon May 11, 2009 5:53 pm
Glad you are sorted.............. Like the tip.
Nick
Welsh Winger
