Brake Pad Assembly - Small Clips
Coolhand
Post by Coolhand » Fri Apr 24, 2009 7:13 am
I changed my front pads the other day. When I did this I noticed one of the clips that fits in the bottom of the caliper was broken with a part missing :(
The one on the right is missing the channel section
This shows a good one in position
I had a look on the Lush Projects database and it is listed as part of a kit 49-290B
Does anyone know where I could get a replacement [-o<
Mike
Veg_Ian
Re: Brake Pad Assembly - Small Clips
Post by Veg_Ian » Fri Apr 24, 2009 7:40 am
These are pretty common on many braking systems so you might get lucky and pick one up without having to order one from a dealer. If you have a decent motor factor near you try taking one in and see if he can do a match. If you get really stuck then maybe Bongobits or a dealer can source one for you.
