Jacking points
kelv
Jacking points
This may seem a stupid question: Anybody advise me where the jacking points are because I cant figure it out from the handbook
Re: Jacking points
Try this thread http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=29471 - it won't help now, but definitely will in the future
- dandywarhol
Re: Jacking points
Front - under the front wishbone/chassis leg bush
Rear - under the trailing arm bush
The jack saddle is curved to accommodate both
kelv
Re: Jacking points
Thanks Dandy
I used those ones myself, but thought there must be an "easier" selection.
You know , like on a "proper" car
In the sill maybe ?
Nah, its a Bongo !
In the sill maybe ?
loftustowncrier
Re: Jacking points
Don't use the sill! It's evident on mine that it has been used in the past - hence the bent bits underneath!
Trouble at t'Mill
Re: Jacking points
And don't use any other part of the wishbone either...
Re: Jacking points
Same here... (but not by me)loftustowncrier wrote:Don't use the sill! It's evident on mine that it has been used in the past - hence the bent bits underneath!
Re: Jacking points
If you use button "Search" and keyword "jacking points", you can find pic with jacking points
http://www.igmaynard.co.uk/bongo/forum/ ... 850#p56850
Russian Mazda Friendee Club
http://www.mazdafriendee.ru
