Im so lucky!!!!
Gaza69
Im so lucky!!!!
Post by Gaza69 » Mon Apr 20, 2009 7:28 pm
I cant belive it, today i had a call from my mechanic, he said the bits are in for the service i need and to bring it to him on wednesday, so i said ok.
When i finished work however i decided to go and say hello before hand to catch up (hes my uncle btw =D> ) and have a look at what he had bought in for me. I only live around 5 miles from work and his garage in only half mile from my home. so not a very long journey. When i had pulled up, whent to get out of the van..................NO..............WHATS THAT......................................STEAMMMMMMMMMM!!!!!! :shock: :shock: :shock: ...............and guess what?
My radiator has gone, flooded his garage area with coolent in around 5 seconds and emptied the tanks. am i luck or what? talk about the right time right place....... 8)
Upon closer inspection, under the big black plastic air intake thing lies the rad, not sure if yours are the same but mine all accross the front edge on the top has about an inch thick foam accross of it??? When touched it crumbled away, so it has to be the origional radiator, on a side note it is probebly worth checking if yours has never been changed. This is where my rad has gone anyway. When he removes it i will try and take some pics before it goes in the skip.
On a major co-insidence, while on my lunch break at work :wink: i was looking at coolant alarms, so when the new rad goes in, so will one of these too.
If any of you are reading this and thinking, "ok its a serious matter, il check everyday but it probably wont ever happen to me!"........Your most likely in for a big expensive shock. :| Heed the advice given on here many many times, get yourself a coolant alarm!
If i hadnt pulled up when i did, but instead continued on home half a mile away i prob would of done some serious damage! hopefully i havent. [-o< [-o<
The choice is always up to the owner ofcourse :wink: , its £70 plus fitting or another £5000 for the van of your choice??
mikexgough
Re: Im so lucky!!!!
Post by mikexgough » Mon Apr 20, 2009 7:37 pm
sounds like you are lucky...... I was happily listening to my rad fans running today while in traffic here... :D :D .... without my aircon on... =D>
Gaza69
Re: Im so lucky!!!!
Post by Gaza69 » Mon Apr 20, 2009 7:38 pm
a barve man without aircon, i tried mine before all this happened and that doesnt work either. :cry: :cry:
Its a very sick van indeed. :cry:
Vicky007
Re: Im so lucky!!!!
Post by Vicky007 » Mon Apr 20, 2009 8:16 pm
I had the same Problem 2 weeks ago, pulled into the esso garage to get diesel and steam startd pouring out of bonnet and from under van due to a split coolant hose and was lucky i was pulling into garage at the time and not on a fast piece of rd as i would have had serious over heating problem, luckily all sorted now and have now gone out and puchased a coolant alarm really is a must for us Bongo owners and is money well spent.
mikexgough
Re: Im so lucky!!!!
Post by mikexgough » Mon Apr 20, 2009 8:21 pm
yep I have a coolant alarm.............. lo and the new Hi level one......
Gaza69
Re: Im so lucky!!!!
Post by Gaza69 » Mon Apr 20, 2009 8:32 pm
where did you get yours from?? and recomended suppliers?
Re: Im so lucky!!!!
Post by francophile1947 » Mon Apr 20, 2009 8:34 pm
Gaza69 wrote:where did you get yours from?? and recomended suppliers?
Send a PM to Haydn Callow - he sells them :D
Gaza69
Re: Im so lucky!!!!
Post by Gaza69 » Mon Apr 20, 2009 8:59 pm
http://www.coolantalarm.co.uk/
Wouldnt be his site by any chance? this is what i was looking at during my break today!
mikexgough
Re: Im so lucky!!!!
Post by mikexgough » Mon Apr 20, 2009 9:16 pm
yep...... pm him....
Gaza69
Re: Im so lucky!!!!
Post by Gaza69 » Mon Apr 20, 2009 9:27 pm
mikexgough wrote:yep...... pm him....
i have. 8)
Gaza69
Re: Im so lucky!!!!
Post by Gaza69 » Mon Apr 20, 2009 11:19 pm
Has anyone found a good / cheap supplier of radiators? other than bongobits and ebay??
cheers.
Gaza69
Re: Im so lucky!!!!
Post by Gaza69 » Tue Apr 21, 2009 1:02 pm
Update**just bought one off bongobits for £140.00ish including vat, a very good price indeed. ALthough they do stock the oem Mazda one aswell. :wink:
Will be fitting it probably on friday, so like i said i will try and get some pics if any one is intereseted? :-s
Re: Im so lucky!!!!
Post by missfixit70 » Tue Apr 21, 2009 1:07 pm
Pics are always good :D , they could maybe be included in the factsheet - http://www.igmaynard.co.uk/bongo/member ... diator.pdf .
Gaza69
Re: Im so lucky!!!!
Post by Gaza69 » Fri Apr 24, 2009 1:21 pm
Good news, my rad has been installed and everything works fine. checking my coolant evey time i get in it to begin with though just incase. :wink: and then every day as normal.
Unfortunalty my uncle did the change over with out me so there are no pics of it :roll: :cry:
But atlease its another bongo on the road again. YEY!
When i went to pick it up, there where a few of his customers around that i started having a chat with and my van came up in conversation, i love seeing peoples faces and reactions when they see the conversion hiding in the back. :lol: just makes me happy i bought something different from the norm everytime. :D
Re: Im so lucky!!!!
Post by haydn callow » Fri Apr 24, 2009 4:01 pm
Did your uncle know the correct method to bleed the cooling system ??
Haven't seen a order for a alarm yet.
