OIL CHANGE
OIL CHANGE
I HAVE FOUND THE DIP STICK UNDER PASSANGER SEAT BUT UNABLE TO FIND OIL FILLER CAP!! I MAY VERY WELL BE THE DIPSTICK HERE, BUT CAN ANYONE HELP PLEASE. MY BONGO IS A V6 2.5 PETROL, MANY THANKS PETE
Re: OIL CHANGE
Seem to remember it being on t'other side under the drivers seat? May be wrong though.
Take your caps lock off Pete, no need to shout
Re: OIL CHANGE
missfixit70 wrote: Take your caps lock off Pete, no need to shout
Insert Bongo pun here
Re: OIL CHANGE
Cheers Kirsty, I will have a look theremissfixit70 wrote:Seem to remember it being on t'other side under the drivers seat? May be wrong though.
Re: OIL CHANGE
It's just above the dipstick on mine
Diesel .
Would be different on a V6 though
Diesel .
Re: OIL CHANGE
Tis on the tuther side
pain in the arse cause when your filling you have to stop walk round the otherside check level, go back fill some more check etc, first time was frustrating shall we say, but get it dead on now first time
Dar
Dar
Re: OIL CHANGE
cheffy34 wrote:Tis on the tuther side![]()
Dar
Longer arms? or a funnel with a bit of hose?
Re: OIL CHANGE
That's quite good actually... It gives the oil more time to settle in the sump, better chance of an accurate read...cheffy34 wrote:Tis on the tuther side![]()
Dar
Re: OIL CHANGE
Thanks giys got it sused out now, many thanks Petebigdaddycain wrote:That's quite good actually... It gives the oil more time to settle in the sump, better chance of an accurate read...cheffy34 wrote:Tis on the tuther side![]()
Dar
