Hi, firstly i dont know how to check the fluid level in the auto gearbox and secondly im not sure what the S and L is for on the gear shifter can anyone explain Thanks
Loads of info on here if you do a search. Here's one for the S and L http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=30338
Checking the level requires driving for a few minutes to get the ATF hot, put the lever into D and apply the handbrake (chock the wheels as well if your handbrake is not too good). Dipstick is under the driver's seat.
