knocking sound drivers side
ccrobins
Post by ccrobins » Thu Apr 16, 2009 12:58 pm
just driven my bongo for the first time in 6 months as was ioff the road for winter. I drove it down to the MOT station and it drove great but was a knocking, this was picked up as an advisory note (Bongo passed no problem) and the guy said its probably either a worn top bush or the spring
now there was no knocking when i last drove it and put it to bed for the winter so i am guessing its the top bush as i believe its rubber and so probably corroded ? or bearing in mind its been off the road could something need lubricating ?? or could it be something else ?
if it is the top bush is this something i can do ? is it a big job / expense ??
any advice appreciated
Re: knocking sound drivers side
Post by bigdaddycain » Thu Apr 16, 2009 2:11 pm
Likely suspects are the front droplinks, or the ball joint bush.
ccrobins
Post by ccrobins » Thu Apr 16, 2009 3:20 pm
are ball joint bushes or droplinks something that an amateur can do ? if not does anyone know roughly how much parts/labour is ?
Post by mikeonb4c » Thu Apr 16, 2009 3:53 pm
ccrobins wrote:are ball joint bushes or droplinks something that an amateur can do ? if not does anyone know roughly how much parts/labour is ?
Droplinks (and anti roll bar bushes, which can also cause clonking) are provided you have six sided socket spanner and extension arm, in order to get a good grip on the nuts, and provided the are not badly seized on (else they have to be ground off with an angle grinder I gather). If you have the tools then it's worth a try before handing it to a garage.
Don't know about ball joint bushes (or what they are) but they sound trickier to me!
ccrobins
Post by ccrobins » Mon May 11, 2009 2:14 pm
it was the droplinks - all sorted now though i did take it to a garage to have it done - i dont trust myself enough with steering etc - 50 quid job done so i'm happy - had a test drive to derbyshire on last weekend - all is well
