Hi people, newbie needs help.....
Aunt Trumpet
Post by Aunt Trumpet » Mon Apr 13, 2009 11:04 pm
Hi, sorry, just realised this should be in techie,
Ive just bought a 4x4 2.5TD, I'm not too bad with a spanner so aim to do all the servicing and stuff myself. However, after looking at the air filter it needs a change so I'm going to do a little service on it including oil and filter, it had a cam belt not long back so what I need to know is:
1. What other filters should I change while I'm at it and where can I find them?
2. Is it easier and cheaper to buy them seperately from other sites or a service kit from here?
3. is there anything else you'd recommend I'd do?
Also it could do with a clean inside, so can anyone recommend anything to use on the upholstery? I'd also like to wash the blinds but it looks a bit tricky getting them off, any ideas how I can clean them?
Thanks for any advice in advance.
You've Been Bongod
Re: Hi people, newbie needs help.....
Post by You've Been Bongod » Mon Apr 13, 2009 11:19 pm
change the fuel filter and if not been done check the water hoses and change the anti freeze BUT its better to get a garage to change the anti freeze because if you don't bleed the system properly you could cook the head :wink:
Aunt Trumpet
Post by Aunt Trumpet » Mon Apr 13, 2009 11:27 pm
ok mate cheers,
can you describe where the fuel filter is? only had a quick look earlier.
8)
Post by missfixit70 » Mon Apr 13, 2009 11:32 pm
Aunt Trumpet wrote:Hi, sorry, just realised this should be in techie,
Welcome to the forum :D
1 - as Carl said, the fuel filter ( under the drivers seat - you should be able to get it off from above) if it hasn't been done in the last year, check the banjo filter (fuel strainer) on top of the fuel pump too, factsheets in the members area on both.
2 - try your local motor factors, may be worth getting a K&N air filter, around £40 initially, but you don't have to touch it for 50k miles, then you reuse it.
3 - thorough flush of the coolant system, along with a check of all the hoses , pipes rad etc, probably worth changing the thermostat while you're at it, just did mine & the one that came out opened a fair bit later than the new one when I tested them in a pan of water on the stove.
Also drop or pump out the gearbox fluid, drop the pan carefully so you reuse the gasket, clean the filter, blow through the oil cooler pipes & replace with clean Dexron III.
Be worth doing the diff oil too.
For the blinds, there is an excellent factsheet in the members area on removing them to clean - definitely woth it - a bit tricky, but once you've done one, you'll get the hang of it :wink:
That should keep you busy for a coupla days :D
Eat Aunt
Location: Bongoing since 2005 in the Portsmouth area :)
Post by Eat Aunt » Tue Apr 14, 2009 12:02 am
Aunt Trumpet
How about a day visit to the Southern Softies meet on the Saturday 18th April if you cant do the Friday or Sunday ? Its sort of North East of Blazingsmoke I think
Plenty of Techie experts there sure to offer help and expertise :D
20 YEARS BONGO-ING
Black Std 2WD AFT
Now 2001 WHITE V6 Tintop ... 253,000 Km
Aunt Trumpet
Post by Aunt Trumpet » Tue Apr 14, 2009 5:02 pm
would do mate but i've got the winchester triathlon in the morning and Rich and Kelly might be with us, if i'm not dead we might be able to get there. :wink:
Eat Aunt
Post by Eat Aunt » Tue Apr 14, 2009 10:22 pm
Aunt Trumpet
You see what its like here ...brilliant =D>
You have you're Bongo 5 minutes and look at all the help you get on this schplendid site.
Hopefully it wont be too long until Aunt Eabe gets her Bongo when she retires. \:D/
Eat Aunt
20 YEARS BONGO-ING
Black Std 2WD AFT
