which engine oil to use
peanutcrusher
Post by peanutcrusher » Mon Apr 13, 2009 10:18 am
I was looking at use GTX Magnatec will this be ok to go in my bongo, also what weight oil do need. will i need to do an oil change if i switch to Magnatec if i can use it that is.
Bongo now work later !!! :) :)
Re: which engine oil to use
Post by Doone » Mon Apr 13, 2009 10:36 am
If you put the words oil AND change into the 'search' box, you'll get a lot of results that will help :) ...this is one of them: oil AND change.
