Harry Potter & the mystery of the missing warning lamp.
Posted: Tue Apr 07, 2009 5:33 pm
by jaylee
Just been looking at the back of my dial pod..
Now i know the empty one at the top on the right is an AFT up warning light. (I have a tin top.)
But the one at the bottom next to the rear demist on light says belt.. & there's no bulb!
Now, i swapped bulbs & started the engine... It don't light up.. I guess it shouldn't.?
Or should it light up pre ignition check style like all the rest?
We all know why warning lamp bulbs are removed..
& bear in mind i've had no real problem in over two years.. (Except the top hose.)
What's the deal??
Re: Harry Potter & the mystery of the missing warning lamp.
Posted: Tue Apr 07, 2009 5:40 pm
by waycar8
check the drivers seat, there should be a wire that goes onto the belt locking bit, dont know if they were optional extra but every bongo i have seen have them on.
When working correctly it stays on untill you put your seat belt on (well lock it)
Posted: Tue Apr 07, 2009 5:42 pm
by jaylee
Sorry not the seat belt.. That works..
Its the one on the right side of the dials with a picture of an engine on it & says belt??
Posted: Tue Apr 07, 2009 5:45 pm
by waycar8
not sure, unless its for the v6. my diesal bongo doesnt have one (well cant see one anyhow
by jaylee
Below the sediment light.. A lopsided triangle with a circle in each corner, like the belt on an engine..?
I'll add i have an SGL5 diesel 2.5 automatic.
Posted: Tue Apr 07, 2009 6:36 pm
by scanner
Perhaps it's a light to tell you your cambelt has broken
Posted: Tue Apr 07, 2009 6:37 pm
by francophile1947
Can't see one on mine either
Posted: Tue Apr 07, 2009 6:52 pm
by stilldesperate
Hi Jaylee,
I looked on mine a couple of months ago, when I re-did the speedo.
From memory, there were one-or-two bulbs spaces spare, I
think it is a cam belt (replace me now!) warning light, but it's not wired in to the vehicle loom.
My thought at the time was that the back circuit board is probably used in different vehicles, and some have it connected, some dont.
I was going to re-use the spare place for a rear fog light, but thought a light with "belt" lighting up might not pass the MOT
I wouldn't worry about it, I've found loads of connectors that do nothing !
SD
Posted: Tue Apr 07, 2009 9:39 pm
by jaylee
Well it looks a bit like this.. But illuminates in red! (I put an LED behind it.)
Posted: Tue Apr 07, 2009 10:06 pm
by stilldesperate
Yup, that's the one!
If you follow the pcb copper track from the lampholder to the edge connector, I'm sure you'll find there's no wiring to it.
I'm taking mine off this next week to replace a bulb, I can double check then.
SD
Posted: Tue Apr 07, 2009 10:25 pm
by jaylee
stilldesperate wrote:Yup, that's the one!
SD
Cheers fer that.! I was planning wiring a bulb (on a separate circuit) using the empty for another function..
If it has no purpose i will use it!
I was going to use the redundant AFT warning lens but that appears to be closed over even though there's a hole for a bulb at the back & i remember seeing the red lens on the front when i fitted the white dials a year or so back.
Posted: Tue Apr 07, 2009 11:17 pm
by stilldesperate
We've done the same stuff, Jaylee
I shone a torch down the spare holes as well, and you're right, some are blanked off completely.
Scope for a bit of DIY lighting, I feel
SD
Posted: Wed Apr 08, 2009 1:48 pm
by helen&tony
Ah So!...now I see it ......DON"T CONNECT ANYTHING TO THAT ONE
....just saved you in the nick of time.....it's the upside-down Japanese chastity belt warning light!!!!
Seriously, could it be something to do with the aircon belts....maybe indicating breakage....whatever it's for, I haven't got mine illuminating...but the idea of using all these spare warning lamp lenses appeals....I think I'll be sending for a box of LEDs and some switches
Posted: Wed Apr 08, 2009 2:33 pm
by jaylee
Checked it out yer right... It's not connected to anything on mine, just a spare.!
Next time i come on here asking what the belt light means & is it a serious problem cuz it's lit.. tell me to turn my rear fog light off...!
