Door Card Removal
Posted: Sat Apr 04, 2009 9:03 pm
by wishmaster
Hi everyone, as i'm new to bongoing can anyone explain to me how to remove the front door cards so i can access the inside. Cheers
Re: Door Card Removal
Posted: Sat Apr 04, 2009 9:10 pm
by steviebongo
hi there its quite straight forward remove the door pull screw and then ease of the door trim,gently prise the around the edge of the trim.
cheers stevie
Posted: Sat Apr 04, 2009 9:11 pm
by missfixit70
Check the factsheet in the members area for the central locking fitting one, that should help.
Posted: Mon Apr 06, 2009 1:28 am
by bigdaddycain
Remember to undo the screw holding the interior handle too, when you are happy the trim is free, lift it upwards so the rubber lip on the window seal doesn't snag, it's easier to remove with the window open.
Posted: Mon Apr 06, 2009 8:22 am
by dandywarhol
There's also 2 crosshead screws at the front of the card and one under a plastic cover at the rear - not quite as straightforward as the above posts say but still easy to do
