Door Card Removal
wishmaster
Door Card Removal
Post by wishmaster » Sat Apr 04, 2009 9:03 pm
Hi everyone, as i'm new to bongoing can anyone explain to me how to remove the front door cards so i can access the inside. Cheers :?
I have a plan and its as HOT as my pants
IZZY
http://s633.photobucket.com/albums/uu57/izzy2619/
steviebongo
Re: Door Card Removal
Post by steviebongo » Sat Apr 04, 2009 9:10 pm
hi there its quite straight forward remove the door pull screw and then ease of the door trim,gently prise the around the edge of the trim.
cheers stevie
Post by missfixit70 » Sat Apr 04, 2009 9:11 pm
Check the factsheet in the members area for the central locking fitting one, that should help.
Post by bigdaddycain » Mon Apr 06, 2009 1:28 am
Remember to undo the screw holding the interior handle too, when you are happy the trim is free, lift it upwards so the rubber lip on the window seal doesn't snag, it's easier to remove with the window open.
dandywarhol
Post by dandywarhol » Mon Apr 06, 2009 8:22 am
There's also 2 crosshead screws at the front of the card and one under a plastic cover at the rear - not quite as straightforward as the above posts say but still easy to do :roll:
