Help need photo of connector under airbag
Jolly Rogers
Post by Jolly Rogers » Fri Apr 03, 2009 2:57 pm
Well managed to remove my steering wheel without breaking my nose :D but managed to inadvertantly pull the wires out from the connector for the horn :oops: I have three wires but not too sure which way they go :? Can some please post a photo or tell me which way they go round thanks yours rather embaressed
Jolly Rogers :oops:
Re: Help need photo of connector under airbag
Post by g8dhe » Fri Apr 03, 2009 3:44 pm
Here are the diagrams and locations inside the cab area;
the WL-T is a slight variation;
and inside the cab area these are the locations;
Not quite sure why three colours but there seems to be an unused module (E1-01), which will have G/O (Green/Orange ?) and G/R (Green/Red ?) going into it, the switch will have the G/R and most likely Black as the ground wire going to it.
Jolly Rogers
Post by Jolly Rogers » Fri Apr 03, 2009 5:12 pm
Thanks for the reply and pictures. :oops: I still cannot work out which holes the wires go in . Here are some pictures
,maybe someone can have a look at theres and advice [-o< [-o<
Yours Jolly Rogers in the dog house :cry:
Post by g8dhe » Fri Apr 03, 2009 9:33 pm
Which year are you 1995-1997 or 1997-1999
Jolly Rogers
Post by Jolly Rogers » Fri Apr 03, 2009 9:43 pm
g8dhe wrote:Which year are you 1995-1997 or 1997-1999
1997-1999 [-o<
Post by g8dhe » Fri Apr 03, 2009 11:08 pm
Ah ha here you are the E1-01 connector whilst maybe only be showing with 1 wire in use is actually as below;
it has 5 receptacles on the lower and three on the upper - but obviously not always all connected ....
Trouble is yours shows 6 connectors on only a single row......
However some of the colours match up ..... R/W Red/White, R Red & G/R Green/Red
Doh ......
I guess the connector can't be seen when the wheel is in place ? But I'll have a look at ours tomorrow ... but I'm not taking the wheel off [-X No way :!:
Jolly Rogers
Post by Jolly Rogers » Fri Apr 03, 2009 11:10 pm
Don't worry you don't have to take the wheel off :D Just undo the 4 bolts at the back to lift off the airbag [-o<
brorabongo
Post by brorabongo » Sat Apr 04, 2009 2:09 pm
Hope this helps....
Mines a 96 though.
I would be s*****g it reconnecting, incase it goes off 8-[
Take care. [-o<
ボンゴの激怒 pictures
waycar8
Post by waycar8 » Sat Apr 04, 2009 3:00 pm
hmmn, been out and had a look at mine, mines 97 r, but...........
yellow with red stripe is the end wire
yellow with black stripe is the middle wire
green with red stripe is the other end wire thats closest to the open ports in the block
not much help i am afraid but maybe help someone in the future
Jolly Rogers
Post by Jolly Rogers » Sat Apr 04, 2009 5:22 pm
=D>
You guys are really great thanks
Right wish me luck. :shock:
I am going to re connect it :shock:
If I don't post back in twenty minutes............. It was great knowing you all
Jolly Rogers
Post by Jolly Rogers » Sat Apr 04, 2009 5:31 pm
:D :D :D
Thanks brorabongo and Waycar8 . I owe you two big time.
by the way any one who thinks a Mazda MX6 leather steering wheel will fit [-X [-X [-X [-X [-X [-X
Don't even think about it :oops: :oops: :oops: :oops:
waycar8
Post by waycar8 » Sat Apr 04, 2009 6:34 pm
so have you reconected your old steering wheel??
Jolly Rogers
Post by Jolly Rogers » Sat Apr 04, 2009 6:39 pm
Yes :oops: :oops:
brorabongo
Post by brorabongo » Sat Apr 04, 2009 7:21 pm
[quote="Jolly Rogers"] Thanks brorabongo and Waycar8 . I owe you two big time.[quote]
Your welcome. :D
ボンゴの激怒 pictures
waycar8
Post by waycar8 » Sat Apr 04, 2009 7:33 pm
so come on spill the beans..............why didnt the mx6 steering wheel fit?, airbag not campatible?
