No air blowing on to my windscreen
wazzie
Post by wazzie » Mon Mar 30, 2009 10:48 am
I've had an ongoing problem with the lack of air coming out of the windscreen vents.. All other vents work fine without any issues. I asked my mechanic to have a look but he said he could'nt find any blockages, not sure if he looked to be honest. Any idea's?
Cheers!
helen&tony
Re: No air blowing on to my windscreen
Post by helen&tony » Mon Mar 30, 2009 10:57 am
The usual problem is the little clips on the cable ends have popped off the lug on which they sit. Have a look in the footwell at the side of the heater chamber....all will be instantly clear....check both sides...driver and passenger.
Post by g8dhe » Mon Mar 30, 2009 11:03 am
Kirsty (Missfixit7) has done an excellent page with all the links in the FAQ, could be link mechanism own by the drivers feet.
wazzie
Post by wazzie » Mon Mar 30, 2009 11:24 am
Thanks for the speedy reply, do you know if there are any pictures of what i should be looking for because i haven't got a clue?
Nice 1...
Post by g8dhe » Mon Mar 30, 2009 11:37 am
These are the most common picture of the links;
This one has bits missing !!!
wazzie
Post by wazzie » Mon Mar 30, 2009 11:42 am
Thats great , thank you very much for your time and effort, just one more question, where do i locate theses clips?
KeEp On TrUCkInG!
Post by g8dhe » Mon Mar 30, 2009 1:46 pm
The heater chamber is the box that sits in the middle of the footwell between driver and passenger, on each side of it there are various mechanical linkages, the exact type depends on the type, year of the vehicle and air conditioner. If you read thru all the links that the FAQ link above gives you will understand better - the exploded diagrams from the Lush projects links and if your a member of the club then the members fact sheets go into great detail on how to repair each element there are 5 fact sheets, and 15 exploded diagrams each with every single component linked to with its part number. after that there are the discussions on the site here, use the forum search page see link in the top right corner or click here.
Good luck.
