AFT roof stuck closed
BongoNess
Post by BongoNess » Sun Mar 29, 2009 7:20 pm
Just had a neighbour pop round with his Bongo.
The AFT roof is stuck in the closed position. He says he's checked the switch and all the fuses, and with the roof closed there's no obvious access to the motors or mechanism so we're a bit stuck for ideas. - Anyone got any suggestions?
Thanks...
You've Been Bongod
Re: AFT roof stuck closed
Post by You've Been Bongod » Sun Mar 29, 2009 7:21 pm
have you made sure your handbrake is on ????
and engine running in neutral :wink:
Jolly Rogers
Post by Jolly Rogers » Sun Mar 29, 2009 7:59 pm
You've Been Bongod wrote:have you made sure your handbrake is on ????
Or in Park?
Post by missfixit70 » Mon Mar 30, 2009 9:58 pm
Check the handbrake switch itself under the console, may not be making contact properly. Is there any noise coming from the motors as if they're trying?
BongoNess
Post by BongoNess » Thu Apr 02, 2009 10:27 pm
Thanks for the replies. I'll get him to check the handbake switch. He say's he can hear a clicking noise from the roof when he tries to raise it which suggests that the motors are trying to open, but are stuck.
Anyone ever tried to take a roof off from the closed position?
Cheers,
Steve
Post by missfixit70 » Thu Apr 02, 2009 10:32 pm
You'd need to be Mr Tickle.
Post by Bob » Thu Apr 02, 2009 10:50 pm
Is it 'Beeping'?
Post by missfixit70 » Thu Apr 02, 2009 11:10 pm
Be worth trying to give it a helping push up while pressing the button, not too hard though, don't want to break anything.
I know you said it was making a clicking noise, but it'd be worth checking the fuse - no 12, 30 amp fuse 4th from left on the second row.
BongoNess
Post by BongoNess » Sat Apr 04, 2009 4:00 pm
Just spoken to my neighbour again. He's tried pushing it from underneath and he's checked the handbrake switch. He says it does beep when he presses the button.
Sounds like this isn't a common problem so I'll post an update if and when he does get it fixed in case it happens to anyone else...
Cheers,
Steve
