whirring sound on acceleration
flyingdoc
Post by flyingdoc » Thu Mar 26, 2009 2:56 pm
hi bongoliers,my tintop 4wd automatic 96 has developed a high pitched whirring noise when i accelerate, as soon as i ease off into a leisurely cruise... it stops whirring ! nothing seems to be hampering its performance generally, I'm concerned it may be auto gearbox trouble or some part of the transmission,any clues? :roll:
David Edwards
Re: wirrring sound on accelleration
Post by David Edwards » Thu Mar 26, 2009 2:59 pm
Mine is doing the same and I know it is one of the belts, check yours in case.
Post by haydn callow » Thu Mar 26, 2009 4:09 pm
Almost certainly a sheared off No 1 Manifold stud...Very common and a easy fix by a decent garage or good DIY.
The stud is the only one you can see ....under passenger seat slightly above and right of the alternator....loads of info on here if you search.
Post by haydn callow » Thu Mar 26, 2009 4:11 pm
flyingdoc
Re: whirring sound on acceleration
Post by flyingdoc » Thu Mar 26, 2009 5:38 pm
hi, re wirrring sound,i've checked no1 manifold stud.. all looks hunky dory...there's no wirring sound when i rev engine while stationary,praps i'll change the belts..then check again. :?
stilldesperate
Post by stilldesperate » Thu Mar 26, 2009 5:42 pm
Does it sound at all like like air sucking in?
"The older I get, the faster I was"
David Edwards
Post by David Edwards » Fri Mar 27, 2009 10:22 am
Just to be on the safe side I checked my stub as per photo and I can see threads only now does this mean that there should be a nut on there and it is missing or is it normal just to show the thread, can't see fully from the piccie.
Happy Camper
Post by Happy Camper » Fri Mar 27, 2009 10:33 am
As my seats are currently up i'll pop out and have alook and tell you what mine is like.
Happy Camper
Post by Happy Camper » Fri Mar 27, 2009 10:39 am
Just checked and mine has nut on the stud so guess yours should have also, I do hope this helps.
Happy Camper
David Edwards
Post by David Edwards » Fri Mar 27, 2009 10:44 am
Absolutely superb, thanks for taking the time. off to garage now, lol.
Happy Camper
Post by Happy Camper » Fri Mar 27, 2009 10:46 am
My pleasure.
David Edwards
Post by David Edwards » Fri Mar 27, 2009 6:19 pm
Just got her back from garage, complete with oil change ( i just mentioned this morning it was due) nice job done, rather awkward tho to get at but very pleased and only cost me £50.00 I am happy with that. :D Oh and one of the belts was a little loose, lol.
