HELLPPPP!!!! Won't start. And wedding Friday
samuel
Post by samuel » Wed Mar 25, 2009 8:55 pm
Tried to start the Bongo. Engine turns beautifully but won't fire up.
Changed the glo-plugs recently and keep meaning to change the glo-plug relay as it still misfires a bit on start up.
Does glo-plug failure contribute to it not starting at all?
Or anybody any other ideas?
The fuel tank is showing a quarter full.
We're off to Paul and Sue's Bongo wedding on Friday!!!
Elpp!! Pleeze!
"Living the Dream"
Re: HELLPPPP!!!! Won't start. And wedding Friday
Post by mikeonb4c » Wed Mar 25, 2009 8:58 pm
Well I reckon you'll have to search on here for how to test voltage supply to the relay and the nget the multimeter out. If that (and glowlugs) is fine then move on to fuel system stuff like banjo filter etc.
Anyone else able to add to that? Good luck [-o<
dandywarhol
Post by dandywarhol » Wed Mar 25, 2009 9:04 pm
Did you fit decent branded glow plugs?
Post by francophile1947 » Wed Mar 25, 2009 9:05 pm
As Mike says, check power to the glow plugs. An easy way is to just disconnect the wire from the bar and use a bulb to bridge the circuit - with the ignition on :D
It has been rather cold lately, so it might be worth charging your battery, for extra boost.
Nevets
Post by Nevets » Wed Mar 25, 2009 9:37 pm
Hi tim nice to see you on here allbeit on desperate terms :cry:
have you tried a test light or multimeter on the glow plug wire/rail when the ign switched on?
does the glow light come on?
tried any of the dredded easy start that may rule out glow plug or power to them?
have you tried pumping the fuel filter primer to purge any air out?(top of filter)
got any breakdown cover????
Can they wait to get married in august when I'm down yr way again?? :lol: :lol: :lol:
Cheers and hope you get sorted Steve [-o<
I am the only bongo in the village.......(not anymore there's two of us now "Damn it)
samuel
Post by samuel » Wed Mar 25, 2009 10:02 pm
Thanks for the support and tips guys.
Will do as suggested tomorrow.
Incidentally where is the glo-plug relay?
"Living the Dream"
scanner
Post by scanner » Wed Mar 25, 2009 10:07 pm
Nevets wrote:have you tried pumping the fuel filter primer to purge any air out?(top of filter)
Not all Bongos have one............... [-X
Post by Bob » Wed Mar 25, 2009 10:14 pm
Don't know where exaxtly it's located, but you can normally hear it 'Clunk' on and off.
Good luck Tim, see you there. [-o<
Post by Doone » Wed Mar 25, 2009 11:46 pm
Tim you have a pm from Allan, which should solve the problem.
madmanwayne
Post by madmanwayne » Wed Mar 25, 2009 11:47 pm
dunno if this will help but my relay is located on the inner wing behind the main battery on the drivers side! SGL3 95(n) is what bongo i have good luck :wink:
Post by Bob » Wed Mar 25, 2009 11:53 pm
Tim, I'll PM, but if you can get a lift up I'll bring a spare tent.
samuel
Post by samuel » Thu Mar 26, 2009 12:09 am
Allan
I will do the checks you have described.
Wayne
I'll check the location you describe.
We're still coming if the Bongo doesn't work. In my T4 works van!! Eeek!! Thank you for your offer.
Tim
"Living the Dream"
Post by Bob » Thu Mar 26, 2009 12:26 am
T4 Welcome 'cos you think Bongo. :D
Post by missfixit70 » Thu Mar 26, 2009 1:02 am
Check the fuel solenoid is getting voltage & opening too, can't have you turning up in a :-& :-& VW [-X :lol:
not so old
Post by not so old » Thu Mar 26, 2009 1:13 am
I am no technie, but wanted to say I hope you can get sorted in time and I have my fingers crossed for you. No doubt the guys into technie will sort you out though :)
