split chargers
sajafi
split chargers
Post by sajafi » Wed Mar 18, 2009 10:22 pm
hi all been looking at this kit on egay and am thinking of getting it any views and oppinyons will be greatly recived
item number 110365475922
cheers :mrgreen:
madmile
Re: split chargers
Post by madmile » Wed Mar 18, 2009 10:31 pm
Personally I would get one from Martin Bird - advertises on ebay as 'willinton'.
More up to the job than a 30a relay and specifically designed to do what you need it to do in a bongo.
sajafi
Re: split chargers
Post by sajafi » Wed Mar 18, 2009 10:47 pm
madmile wrote:Personally I would get one from Martin Bird - advertises on ebay as 'willinton'.
just had a look and it looks spot on
scanner
Re: split chargers
Post by scanner » Wed Mar 18, 2009 10:51 pm
That is a spot on description of just what it is...............
mikexgough
Re: split chargers
Post by mikexgough » Wed Mar 18, 2009 10:52 pm
yep as madmile says...the Willinton kits are the business, I got one.....it's all there, easy to fit and then you forget it....no messing...
sajafi
Re: split chargers
Post by sajafi » Wed Mar 18, 2009 10:56 pm
the last photo with the fuse box with the 2 wires going into it is that how it takes over the sterio and the inturnal lights ?
Item number: 220379298946
Re: split chargers
Post by missfixit70 » Wed Mar 18, 2009 11:02 pm
Yep & there should be two extra ones for the blinds if you want or whatever else. Dead easy to fit & great aftercare too :D
steviebongo
Re: split chargers
Post by steviebongo » Wed Mar 18, 2009 11:22 pm
I got one of those system's from martin and its spot on I work in the motor trade and the quality of the kit is second to none ,even down to the fitting/photo instructions.In my opinion u won't buy better for the money and after care fact!
cheers stevie.
dvisor
Re: split chargers
Post by dvisor » Wed Mar 18, 2009 11:30 pm
I seem to remember that I contacted Martin before buying my Willinton kit asking for instructions and he sent them to me via email as a PDF. It's a real doddle to install and a quality piece of kit. Might cost a bit more, but you know for certain that it'll do exactly what you want. He also sells the relay together with a battery tray for a bit more.
Two tonne tin drum
