removing rear spoiler
glynreaper
Post by glynreaper » Wed Mar 18, 2009 6:35 pm
I am thinking about adding a fiamma cycle rack to my bongo, but I have been told that for this to fit the rear spoiler needs to be removed.
Is this a big job?
Also the high level brake light is inside the spoiler obviously if the spoiler is removed are there any legal implications?
Do cars have to have one now?
Glyn
Re: removing rear spoiler
Post by Doone » Wed Mar 18, 2009 6:48 pm
This link also asks about the spoiler :) : http://www.igmaynard.co.uk/bongo/forum/ ... 57&start=0
kimbo
Post by kimbo » Wed Mar 18, 2009 7:12 pm
I fitted one and had to cut out the spoiler which wasnt difficult to do, this left the brake light in place and once fitted it also looks good.
glynreaper
Post by glynreaper » Thu Mar 19, 2009 12:50 pm
so you actually cut the spoiler, do you have any pics would be most useful
So you took the spoiler off an made a couple of slots I am guessing so that the feet of the bike rack had some where to go
northerntaff
Post by northerntaff » Thu Mar 19, 2009 2:19 pm
majorbloodnock has done the whole job.
If you find a post by him, click on his signature link it'll take you to his flickr accounts. There's some close up shots which should really help.
glynreaper
Post by glynreaper » Thu Mar 19, 2009 4:03 pm
Thanx thats exactly what I needed
I think i can actually do that, Does any one know how hard it is to get the spoiler off to so that I can cut the slots
Post by missfixit70 » Thu Mar 19, 2009 11:40 pm
Dead easy to get it off I think, I've had to unbolt one end to fit a ladder for someone, 2 bolts from inside the tailgate at either end, not sure about the wiring, I'd assume it unplugs, I'm sure someone'll be along to answer that one.
daveblueozzie
Post by daveblueozzie » Thu Mar 19, 2009 11:57 pm
missfixit70 wrote:Dead easy to get it off I think, I've had to unbolt one end to fit a ladder for someone, 2 bolts from inside the tailgate at either end, not sure about the wiring, I'd assume it unplugs, I'm sure someone'll be along to answer that one.
Oh my God Kirsty i thought it was franco posting for a moment then. :shock: :wink:
Lost without my Bongo.
Post by Simon Jones » Fri Mar 20, 2009 1:25 am
I seem to recall there was a connector for the brake light & also that it could easily drop inside the tailgate or the the spoiler (can't remember which, but recall making a mental note in case I ever removed it again).
waycar8
Post by waycar8 » Fri Mar 20, 2009 1:45 am
took mine off on on tuther day...............
2 star type screws (not pozidrive) at either side (you have to open the tailgate to see them :wink: ). unscrew them.
, then pull the tailgate down, then just grab the passenger side end and gently pull away from the tailgate, its got like a plastic locking plug that goes into the tailgate,just pushes in and out, then do the drivers side, you will see the wiring for the tailgate going into the spoiler, just unplug the connector block :wink:
kimbo
Post by kimbo » Fri Mar 20, 2009 5:19 pm
glynreaper wrote:so you actually cut the spoiler, do you have any pics would be most useful
Yeah, Unscrewed the spoiler without any problems, unclipped the Light lead and then cut out the slots using a Dremel power tool quite easy, the knack is to get the dimensions spot on. I have photos showing the measurements etc. How do I send them to you?
stilldesperate
Post by stilldesperate » Fri Mar 20, 2009 5:31 pm
waycar8 wrote:took mine off on on tuther day...............
Pretty sure, from memory, they're Torx screws, drivers for these readily available.
SD
"The older I get, the faster I was"
Post by missfixit70 » Fri Mar 20, 2009 5:56 pm
SD
10mm bolts ( I think) with a torx option on mine.
waycar8
Post by waycar8 » Fri Mar 20, 2009 7:30 pm
SD
ah so thats the name for em.......... torx :wink: , mine arnt 10mm bolts thoe just torx screw :wink:
stilldesperate
Post by stilldesperate » Fri Mar 20, 2009 9:32 pm
