windscreen washers
snakes46
windscreen washers
Post by snakes46 » Thu Mar 12, 2009 12:49 am
Two quick questions low pressure on thr front washer jets and has any one fitted a cd changer and where did they put it ?
daveblueozzie
Re: windscreen washers
Post by daveblueozzie » Thu Mar 12, 2009 12:55 am
firstly you cant fit a cd changer onto the windscreen washer jets, :oops: :shock:
Check the pipes are not blocked or twisted, take the pipes off the rear of the jets and see if they squirt out, if they do then check the jets using a pin to clean them.
Lost without my Bongo.
Post by bigdaddycain » Thu Mar 12, 2009 12:28 pm
snakes46 wrote:Two quick questions low pressure on thr front washer jets and has any one fitted a cd changer and where did they put it ?
I fitted a mini-disc changer in my glovebox, dunno if a cd changer would fit there though.... :-k
What he said about the squirter's.... :wink:
