Block Tester
dobby
Block Tester
Post by dobby » Wed Mar 04, 2009 10:19 pm
The FROST catalogue arrived this morning, they sell a product called Block Tester - similar idea to the Magic Coolant in the post by Haydn. It's a test kit for £40 that uses a reagent that turns from blue to yellow if exhaust gases are present in the header tank.
Have a look
http://tinyurl.com/Block-Tester
They also sell the fluid separately for £7.50. Reckon that a cheap syringe could be used instead of the kit? Might be an option if a sniffer test isn't an option?
Re: Block Tester
Post by francophile1947 » Wed Mar 04, 2009 10:27 pm
It does seem rather expensive for the kit :shock: I agree that a syringe should work.
dobby
Re: Block Tester
Post by dobby » Wed Mar 04, 2009 10:31 pm
I'm wondering if the reagent fluid is the same as the Toyota coolant that Haydn spotted - might be an even cheaper option.
Nevets
Re: Block Tester
Post by Nevets » Wed Mar 04, 2009 11:50 pm
Hi guys these kits are for testing for exhaust gases present in the coolant by means of filling the sniffer with a small amount of fluid and the placing in the neck of the header tank and squeezing the black bulb bit quite a few times (pumping action)thus drawing the vapor from the header tank through a 1 way valve, the bubbling action created in the sniffer chamber(the clear bit) and after 30secs+ upto a minute if the blue liquid detects Exhaust gases(carbon monoxide) then it changes to what looks like urine :wink:
The sniffer kit or fluid should not come into contact with the coolant or you have to empty the fluid and clean down the sniffer unit..and start again...
But a good bit of kit though =D>
I am the only bongo in the village.......(not anymore there's two of us now "Damn it)
dobby
Re: Block Tester
Post by dobby » Thu Mar 05, 2009 12:02 am
Ah - so this is the 'sniffer' test kit then.
I'll put the turkey baster back then!
The Great Pretender
Re: Block Tester
Post by The Great Pretender » Thu Mar 05, 2009 1:10 am
I was chatting to a guy from one of the garages that Wheelquick deal with and he said they use that (or similar) to test for exhaust gas. Said it works fine.
To infinity and beyond
dandywarhol
Re: Block Tester
Post by dandywarhol » Thu Mar 05, 2009 4:41 pm
I have a system which detects combustion gas (CO2)in the steam, but it can't be used IN the coolant. A MOT tester could use the 4 gas analyser for testing for carbon dioxide in the steam
dobby
Re: Block Tester
Post by dobby » Thu Mar 05, 2009 7:11 pm
I thought that Dandy's system was the official one, useful to know the block tester kits are out there.
