I have just bought a second hand rear spoiler - does anyone know how I should wire this up i.e. a wiring diagram or description of what to do?
JH
Rear spoiler wiring
Re: Rear spolier wiring
Hi Jay, i'm guessing you had NO rear spoiler originally, and now you need to wire in the LED brake light?
Do you have the two wires exiting the hole in the spoiler? Pull off the weather strip one one side of the tailgate, remove one of the rear light clusters.
Using a multimeter, determine which wires feeding the brake light are live/negative, then simply tap in the wires from the spoiler, the wires from the spoiler can be tucked in behind the weatherstrip to hide them.
If you don't have a multimeter, you can try a 50/50 guess on which wire to splice into the brake light circuit, you won't blow anything (been there, done that) You'll just need to swap the wires over if it doesn't work first time.
Hopefully DBO will clock this thread, he may remember more specifics from when we fitted his spoiler.
- daveblueozzie
erm no , that's what we did.bigdaddycain wrote:Hi Jay, i'm guessing you had NO rear spoiler originally, and now you need to wire in the LED brake light?
If you don't have a multimeter, you can try a 50/50 guess on which wire to splice into the brake light circuit, you won't blow anything (been there, done that) You'll just need to swap the wires over if it doesn't work first time.![]()
Lost without my Bongo.
Thanks for your replies and help - you guessed correctly I am fitting a spoiler to the van and this is a new addition. Work begins next week once the spolier and side awning have been sprayed in a matching colour - so I will follow your advice.
Best wishes
JH
Best wishes
JH
