Rear heater fan noisy
maxheadroom
Post by maxheadroom » Mon Mar 02, 2009 7:25 pm
Rear heater fan noisy when on full anyone got any advice on a cure? [-o<
Keep the Faith
Re: Rear heater fan noisy
Post by missfixit70 » Mon Mar 02, 2009 8:19 pm
Turn the stereo up, or don't turn the fan on? :P
sorry :oops:
Once you've got the side panel off, it's not that difficult to take it out, one or two nuts from underneath the van. It could be something's dropped in the fan? or got caught in the blades maybe? what sort of noise?
May be worth checking the nut's are tight underneath.
maxheadroom
Post by maxheadroom » Mon Mar 02, 2009 8:40 pm
Cheers Kirsty new I could rely on you for a sober answer :wink:
Will have a look at my possible lose nuts at the weekend. :shock:
The noise it make is quite loud and vibrates through the van :D
Keep the Faith
Post by missfixit70 » Mon Mar 02, 2009 8:46 pm
If your nuts are tight, it may be the bearing goosed or even the fan's popped off the spindle somehow. At least spare ones should be readily available from breakers etc (Harry?) if needed, as they don't seem to give too many problems.
jayhaytch
Post by jayhaytch » Tue Mar 03, 2009 6:22 pm
Whilst on the subject of rear heaters - I cannot seem to get my rear heater to work at all. I have the usual vents at the rear of the top of the cab but no heat - does any have any information or advice to offer about this?
JH
Post by missfixit70 » Tue Mar 03, 2009 6:29 pm
jayhaytch wrote:Hi
JH
Have you switched it on from the front? This may help http://www.igmaynard.co.uk/bongo/forum/ ... 43&t=28727
Post by g8dhe » Tue Mar 03, 2009 6:31 pm
You are turning it on from the front ?
You do have a rear control box ?
The temperature slider on the rear control box is slid to the Max ?
