uneven wear in front tires
You've Been Bongod
Post by You've Been Bongod » Fri Feb 27, 2009 10:42 pm
both my front tires are wearing on both edges BUT not in the middle :cry:
and i have a terrible wheel wobble
have changed drop links , re balanced tires
any other help would be appreciated [-o<
Re: uneven wear in front tires
Post by Muzorewa » Fri Feb 27, 2009 10:46 pm
Carl, our fronts wore unevenly when our tracking was out, once we had the tracking set and wheels balanced, things were ok for a while but the uneven wear was still there and we had terrible tyre noise, wheel wobble and tyre wear. Having fitted new front tyres, it's like driving a different car - drives like a dream :wink:
You've Been Bongod
Post by You've Been Bongod » Fri Feb 27, 2009 10:50 pm
thanks muz i will have tracking checked and go from there [-o<
mister munkey
Post by mister munkey » Fri Feb 27, 2009 11:21 pm
What pressure are you on at the fronts Carl?
Wearing at the edges suggests low pressure. I've recently pushed mine up by 5 psi (after a nod on here) as mine were doing the same. Spot on now.
Sorted, the weaves & wobbles have faded & it feels a lot more stable now.
Try fettling the front psi, that maybe all you need.
You've Been Bongod
Post by You've Been Bongod » Sat Feb 28, 2009 7:21 pm
re checked the pressures today and 1 was @ 28psi and the other was 32psi to i topped them all up to 40psi and touch wood seems ok again
thanks for the info guys :wink:
dandywarhol
Post by dandywarhol » Sat Feb 28, 2009 7:48 pm
40 wore the MIDDLE out of mine - now at 35 on an unconverted van...............
You've Been Bongod
Post by You've Been Bongod » Sat Feb 28, 2009 7:52 pm
thanks dandy i will drop the pressure tommorrow to 35psi :wink:
Ron Miel
Post by Ron Miel » Sat Feb 28, 2009 9:19 pm
You've Been Bongod wrote:thanks dandy i will drop the pressure tommorrow to 35psi :wink:
Mine's fully converted, and is handling fine with 35psi front/37psi rear, when in normal runaround configuration - checks in then at 1980Kg on our local weighbridge. Doing our first ever fully loaded (water/petrol/LPG/porta potti header tank all full, full camping kit including awning, etc. on board) camping trip next week, and intend to try taking rear tyres up to 39psi just for that trip.
Also plan to re-visit the weighbridge in that full load condition before setting off, and hope to be at or below Imperial Car Company's specified 2260kg gross vehicle weight - for all Bongo Friendees.
Anyone know where that 2260kg figure comes from? I've seen it quoted elsewhere in the forum but it bears no relation to any of the "vehicle weight" (tare or gross?) figures for different variants in the Owners Handbook. As a non type approved (UK) motor, there's no gross weight listed, in my V5 at least, so I suppose that in the event of an insurance claim I have to rely on Imperial's figure for "legality".
trevd01
Post by trevd01 » Sat Feb 28, 2009 9:23 pm
I have found 40psi works fine. See this thread: http://www.igmaynard.co.uk/bongo/forum/ ... =1&t=28972
20,000 km and hardly detectable wear, edge, centre or anywhere
Maybe the high load rating, quality tyres (Yokhama 100H) in standard tyre size (ours are 215/65R15), perfect tracking, perfect drop links and perfect balance has helped?
Or have we just been lucky with our tyre wear?
Arnold Palmer wrote:It's a funny thing,
the more I practice the luckier I get.
But I have found that I have needed the front wheels balancing at least once a year. As soon as I get that first feeling of a shimmer through the steering wheel at about 64/70 mph, I have got them re-balanced.
:D
brorabongo
Post by brorabongo » Sat Feb 28, 2009 10:42 pm
40psi did my rear tyres in. :cry: They had worn in the middle, just like Dandy's.
ボンゴの激怒 pictures
kawasaki kid
Post by kawasaki kid » Sat Feb 28, 2009 11:56 pm
I run mine with the fronts at 36 psi and the rears at 40 psi - what they quote for towing - tyre wear not noticeable and the ride improve - when I first got the van I used to run at the normal quoted pressures and the rear passengers used to complain about the bouncy ride #-o and I`ve got adjustable shocks on my van. =D>
If I had all the money I ever spent on my Freda ............ I`d spend it on my Freda.
Ron Miel
Post by Ron Miel » Sat Feb 28, 2009 11:59 pm
brorabongo wrote:40psi did my rear tyres in. :cry: They had worn in the middle, just like Dandy's.
Think it's bound to be somewhat vehicle weight dependent - dandy's is unconverted, so 40 psi would have put the tyres right up on tippy toe. Anyway, with that in mind, I compromised and split the difference between the Mazda spec, and the 40psi all round that many people were telling me to use, when running without a full camping load in, and it's absolutely fine. Will try 39psi/rear, only with full rear loads, but any sign of excess centre wear and they'll stay at 37psi, or less, all the time.
Post by bigdaddycain » Sun Mar 01, 2009 12:31 am
:shock: No, no carlos... You need at LEAST 40 in your tyres mate, you are running 18's, dandy isn't.
Mine are 45psi. Wear is almost even, getting a tad low on the inside fronts.
daveblueozzie
Post by daveblueozzie » Sun Mar 01, 2009 12:34 am
I'm on 17's and mine are 40psi as recommended by wheelquick who fitted the tyres.
Lost without my Bongo.
mister munkey
Post by mister munkey » Sun Mar 01, 2009 1:01 am
My last set of 17"s seemed happiest at 36/40 so kept those figures in mind when I got the RX8's.
4000 miles on, the fronts were wearing excessively on the outer edges. Beefed up to 45 all round & the whole caboodle has felt a lot more solid. It seems to make a big difference as to which tyres,wheel size & internal set you have, as to what works best.
