Leak above front window in corner /
xpanse0
Post by xpanse0 » Fri Feb 27, 2009 9:35 am
Hi all
Just wondering about a leak i must have in my bongo. On the drivers side above the side and front window the cover/material thing(for want of a better word) has been very damp after heavy rain.
Does anyone know if this is a known problem perhaps with the pop roof seal or could it be linked to the fact that i have recently had a new windscreen fitted.
Thank you in advance
Steve
Re: Leak above front window in corner /
Post by haydn callow » Fri Feb 27, 2009 9:44 am
If it wasn't damp before the new windscreen then I would suspect that is at fault.
xpanse0
Post by xpanse0 » Fri Feb 27, 2009 9:58 am
hi
thanks for the reply. The problem is,,,, i never noticed it before the windscreen was replaced ( which is not to say that the problem wasn't there before), so thought i would check if there were any known problems before i get on to the insurance company. thanks again
Steve
Post by haydn callow » Fri Feb 27, 2009 10:24 am
Unlikley to be from the roof in the place you say...the roof opening is quite a way back.
