Another glowplug/relay problem!!
Wi11iBongo
Post by Wi11iBongo » Wed Feb 25, 2009 2:02 pm
Hi Guys, Had an accident with the glowplug rail and earthed it out. Dash light comes on and off as normal. It is a 2000 2.5, there isnt a fuse wire from positive battery connection (revision i guess) so my question is will it short out the relay or is there a fuse inbetween? I can't see anything in the bongo and I can't see anything in the members area.
Any help greatly appreciated.
westonwarrior
Re: Another glowplug/relay problem!!
Post by westonwarrior » Wed Feb 25, 2009 3:15 pm
there must be a fuse somewhere
tip put location on your profileand maybe some local advice can come forth like who to take it to to get it checked
Post by francophile1947 » Wed Feb 25, 2009 3:30 pm
Fusible link - see http://www.igmaynard.co.uk/bongo/forum/ ... nk#p271645 and other threads - just search for fusible AND link
Post by teenmal » Wed Feb 25, 2009 3:35 pm
Try fuse No18 10amp..
Cheers Malc..
Post by haydn callow » Wed Feb 25, 2009 3:37 pm
Spot on teenmal....and no fuseable link
Post by francophile1947 » Wed Feb 25, 2009 3:43 pm
haydn callow wrote:...and no fuseable link
:? :? :? - there should be :? :? :?
Post by haydn callow » Wed Feb 25, 2009 3:56 pm
Some seem to have them and others (mine included) not
Post by francophile1947 » Wed Feb 25, 2009 4:02 pm
haydn callow wrote:Some seem to have them and others (mine included) not
Well, you live and learn 8) , mine has :lol: :lol: :lol:
Wi11iBongo
Post by Wi11iBongo » Wed Feb 25, 2009 4:09 pm
Thanks for the replys guys, I should have said before fuse 18 is ok too, checked all fuses under dash.
Post by francophile1947 » Wed Feb 25, 2009 4:10 pm
In that case, you may well have a blown fusible link.
Wi11iBongo
Post by Wi11iBongo » Wed Feb 25, 2009 4:16 pm
francophile1947 wrote:In that case, you may well have a blown fusible link.
Don't think there is one, nothing running from the positive battery terminal.
Post by francophile1947 » Wed Feb 25, 2009 4:25 pm
Pity - that would have been nice and easy 8)
Do as westonwarrior said and put your location in your profile - somebody local may well be able to help :D
Post by teenmal » Wed Feb 25, 2009 4:28 pm
Hi it might be worth checking fuse No6 20amp under the hood,just in case you have a later spec vehicle..
Cheers Malc..
Wi11iBongo
Post by Wi11iBongo » Thu Feb 26, 2009 2:39 pm
Again thanks for the replys, realy appreciate the help. I've now checked all the fuses and they seem fine. I have got a replacement relay on the way, I can only think it's fused itself into the off position, but then maybe the dashlight wouldnt light up!!??!! Ah well I will have a better idea when the relay arrives!.
Post by teenmal » Thu Feb 26, 2009 3:23 pm
Wi11iBongo wrote:Again thanks for the replys, realy appreciate the help. I've now checked all the fuses and they seem fine. I have got a replacement relay on the way, I can only think it's fused itself into the off position, but then maybe the dashlight wouldnt light up!!??!! Ah well I will have a better idea when the relay arrives!.
Hi you might have blown the wire from the relay to the GP rail :idea:
