Washer motor.
fredkeegan
Washer motor.
Post by fredkeegan » Sun Feb 22, 2009 2:39 pm
How do I check the rear washer motor? the water comes out.I have changed the fuse but still no joy.Help
Re: Washer motor.
Post by missfixit70 » Sun Feb 22, 2009 3:00 pm
Not quite sure what you're after, you say the water comes out?
The rear washer pump is supplied from & is mounted on the front washer bottle, it is the higher of the two, so will run out first.
The rear wiper motor sometimes gives problems due to the wiring between the door & the body - factsheet in the members area here - http://www.igmaynard.co.uk/bongo/member ... ardoor.pdf
Re: Washer motor.
Post by mikeonb4c » Sun Feb 22, 2009 3:08 pm
Welcome fredkeegan.
Are you saying the motor is pumping OK and fuse is OK? Has a pipe either going to or coming from the pump become detached, as there have been a few incidences of this reported on here. Have a search for 'rear' and 'washer'.
fredkeegan
Re: Washer motor.
Post by fredkeegan » Sun Feb 22, 2009 3:58 pm
fredkeegan wrote:How do I check the rear washer motor? the water comes out.I have changed the fuse but still no joy.Help
the arm itself does not move. Thank you, give it a go later.
Re: Washer motor.
Post by missfixit70 » Sun Feb 22, 2009 4:08 pm
So it's the wiper motor, check the wiring between the tailgate & the body, the factsheet should help.
