Rear Fog Light(s)
Dolly1
Rear Fog Light(s)
Post by Dolly1 » Fri Feb 20, 2009 8:47 pm
I am intending to re-locate my rear fog light to the bumper,(flush fitting).
I would like to fit 2 rear fog lights but,is it legal,as most modern cars have only the one.
With both fogs on and braking as well,i am mindful of the glare factor.
Opinions appreciated,and maybe an official one (Highway Code)
Lionel
SARAH & LIONEL - I Used to be Citroen 2CV "DOLLY" mad but BONGO-MAD lady with not so mad husband now!
MountainGoat
Re: Rear Fog Light(s)
Post by MountainGoat » Fri Feb 20, 2009 8:57 pm
I don't have a clue if it is legal or not in the UK. But common sense would say that having two rear fog lights would be the perfect arrangement if you intended to take your Bongo abroard, then you would always have a fog light on the off side when driving in either Europe or the UK.
Tony
steviebongo
Post by steviebongo » Fri Feb 20, 2009 9:00 pm
yes it is ok to have 2 fogs ,in the uk its legal requirment for 1 either in the centre or the offside.
cheers.
Dolly1
Post by Dolly1 » Fri Feb 20, 2009 9:04 pm
Hi MountainGoat,
What a good idea,an ideal solution it would appear,
with a two way relay to switch from r/h to l/h
steviebongo
Post by steviebongo » Fri Feb 20, 2009 9:08 pm
why complicate things running 2 fogs is perfectly acceptable wether u go abroad or not.
cheers.
mikexgough
Post by mikexgough » Fri Feb 20, 2009 9:21 pm
why not do as others on here and put one in the right side light cluster...........
You've Been Bongod
Post by You've Been Bongod » Fri Feb 20, 2009 9:26 pm
as long as you have a fog light on the drivers side thats ok
if you dont have one on the drivers side it will fail an mot :wink:
maxheadroom
Post by maxheadroom » Fri Feb 20, 2009 10:23 pm
I posted this a year ago it may help :D
http://www.igmaynard.co.uk/bongo/forum/ ... ht&start=0
Keep the Faith
Dolly1
Post by Dolly1 » Fri Feb 20, 2009 10:37 pm
Hi Max,
Now thats just the look that i am after,brilliant
Lionel
Post by missfixit70 » Sat Feb 21, 2009 5:34 am
Or what about this http://www.igmaynard.co.uk/bongo/forum/ ... og#p273472 no bumper cutting involved :wink: Easily be done on both sides 8)
Dolly1
Post by Dolly1 » Sat Feb 21, 2009 9:44 am
Hi Kirsty,
Yep,like it,thats another option to consider,and a lot cheaper as well !! =D> =D> =D>
